Old 06-03-2008, 11:01 AM   #1
chris71
chris71's Avatar
popping from exhaust/ valve train noise
ok guys, i just got done putting the headers back on last night, and she is popping out the back of the passenger side exhaust, she used to pop before, at idle, its a nice consistant pop, i know i have an exhaust leak at the collector on the passenger side, i seem to have picked up some valve train noise on the pass. side as well (i did switch from 10w30 to 5w30), and when i took the plugs out to put the headers in i noticed #6 plug had some extra caked on carbon build up on the plug. I have have had a collector leak on the same side before and the popping was there too what does this sound like to you guys,
1).could the collector leak be making the pop out the tail pipe and a loose rocker stud nut be making noise in the valve train
2). could a problem in the valve train be causing the pop and the noise in the train
3). could this be a timing or vacuum leak issue (but if it were would the pop/noise be on both sides of the car?
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 06-03-2008, 11:29 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: popping from exhaust/ valve train noise
I guess I would try adjusting the valves. Sounds to me like the valve lash is out of adjustment, the valves are bad, or the timing is off. How many miles on it?
I have been known to be wrong in the past but just some suggestions....
LockDoc
Leon
Old 06-03-2008, 11:34 AM   #3
chris71
chris71's Avatar
dont know, the PO had no idea and the speedo was disconnected, it looks like a fresh rebuild some time ago, based on looks, new parts, maybe 5 to 10 years ago, probably only 20,000 miles or less on it from what i can guess, its not some 130K original motor that is about dead
