Old 06-03-2008, 12:56 PM   #1
SWILL
dash and gauges swap
If i were to install a complete new or restored dash with all factory gauges ** Would this fit in place of any stock dash. Mine is set up where the blinkers and generator light are in where the tach sits. It has an aftermarket tach set up on the column already, I believe its a sun tach, would the wiring for that work for the tach in the restored dash. Im thinking everything should just connect right up, or is it not that easy ? Would love to have that and get rid of all the other after market gauges. Is it unusal that my blinkers are not on the outside of the area where the tach would be. On most the dashes i see they are on the outsides ??
Shane
SWILL is offline   Reply With Quote
Old 06-03-2008, 01:16 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: dash and gauges swap
The "idiot light" gauge panels use a different under-dash harness than the standard gauged panel, so it's not a direct plug-n-play swap. And yes, the idiot light panels have the blinkers in the middle.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-03-2008, 01:27 PM   #3
john
member #16
john's Avatar
Here is a link from gmcpauls for guage dash conversion. You need to make some loom changes. The factory tach uses a seperate loom.
http://www.gmcpauls.com/Tech%20Tips1.htm
john is offline   Reply With Quote
Old 06-03-2008, 01:29 PM   #4
Luvlegs
Luvlegs's Avatar
I did the change out following the directions in the FAQ section - I had to change a few wires around in the connectors to the back of the gauges and then run a couple for the ammeter - it's not real difficult though.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 06-03-2008, 01:39 PM   #5
SWILL
Very cool, thanks very the info. Im pretty green yet so I dont know much !
