Old 06-03-2008, 01:21 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Power steering pump & hose assembly
Would several of you be kind enough to post some photos of your PS pump, how it bolts to a block (big block if you can) and the lines and how they run to the gear box.
I pulled off my box and had it rebuilt and turned into a quicker steer ratio & have since forgotten for sure some of the critical bolt locations and hose routing.
I took several pictures before I removed the assembly but have missed a couple of critical areas.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
