Old 06-03-2008, 04:42 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Radiator Hoses on your serp set up
All you guys/gals out there that switched over to the serp belt. How did you guys run your radiator hoses? Do I just need to go and get the ones for a newer truck? Thanks
Wes
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-03-2008, 07:31 PM   #2
Sammy
Re: Radiator Hoses on your serp set up
Look around find someone with a silverado P/U with a serp setup. Pop the hood check the thermostat housing. If it points the right direction for your application go to the parts store & get that upper hose. That is the safest way to insure you have the correct application.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-03-2008, 07:33 PM   #3
Sammy
You may need the swivel thermostat housing before you are happy with it. Otherwise the upper hose don't like that bracket much.
Old 06-04-2008, 07:42 AM   #4
JayDubBlazer
go cyclones
Thanks, I work with a guy who has an 1990's chevy. Ill ask him if I can take a peek.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 06-05-2008, 03:16 PM   #5
neonlarry
neonlarry's Avatar
For the top I used a #7368 from NAPA. It is a stock chevy hose (I just don't know which Chevy). For the bottom I used a bendable convoluted steel hose.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
