Old 06-03-2008, 11:51 PM   #1
Luvlegs
Luvlegs's Avatar
Does this column stuff appear to be ok?
I am holding up a sale thread because I don't know what I have - I am changing out to a T400 and this column I have. Can anyone tell me if my pointer, etc. look adequate? It needs to be cleaned up but I don't know enough to tell if the fiber optic part is good or if I should get another one. Thanks all for the help. I think it's a 69-72 column correct?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 06-04-2008, 12:08 AM   #2
463
463's Avatar
Re: Does this column stuff appear to be ok?
place a #194 bulb in the socket power it up with 12vdc ( add the power on the brass tabs at the bulb socket) and look at the shift ind. it should a light in there like the 194 bulb. the fiber optic part is good if you have light. the fiber optic cable is good in 99% of the time. the pointer looks good. good luck, 463
Trueman
463 is offline   Reply With Quote
Old 06-04-2008, 12:13 AM   #3
Luvlegs
Luvlegs's Avatar
thanks 463 - I was in bed and realized I was holding someone else up so I got up, went out and took the pics, made the post and just couldn't think of how to keep it simple.. guess I get up EARLY to try it in the am.... before work.... ugh.
1972 C10 L6 3OTT
Old 06-04-2008, 01:01 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
just aim the end towards any light source... even the sun.
Old 06-04-2008, 10:11 AM   #5
Luvlegs
Luvlegs's Avatar
Thank LM - I left too early this am - I'll hit it with a flashlight perhaps when I get home... or the 12v bulb.. I have some spares. I stepped aside on the for sale item until I can say for sure it's what I need...
1972 C10 L6 3OTT
