Old 06-04-2008, 01:04 AM   #1
burning bullet
What way should I go?
I want to start of by saying I'm new here and I have a 67' step side long bed. I recently bought the truck from a friend. I am doing a frame off resto but nothing crazy. I'm only 18 with a part time job. The ? I have is what type of suspension should i use? I want a 2-1/2 frt and 4in rear drop. I plan on having around 400 rwhp and doing a lot of racing street and strip, but I also want to take it to a few car shows. I want power disk brakes on the front and drum are ok in the rear. I also have a shortened rear end with willwood brakes and decent size axles. I don't know if I should use that or the stock rear end with 3.73 gears and posi. So I'm not going all out drag but I want to be able to hold my own.
Thanks,
Andy
burning bullet is offline   Reply With Quote
Old 06-04-2008, 08:23 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: What way should I go?
If you're asking about dropping the truck, then I would go no farther than ECE (Early Classic Enterprises). They have some of the best drop kits on the market. On their site they have different truck/blazer models with different lowering kits on them. It makes it a little easier to see what your lowering kit will look like with out dropping the $$$.
to the board from Mid-MO, and good luck with the build!
By the way...
If you need help on figuring out how to post pics check out this link.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-05-2008, 03:56 PM   #3
burning bullet
Here are a few pics the rotors need to be resurfaced from the winter.
Old 06-05-2008, 03:57 PM   #4
burning bullet
more of the rear end
Old 06-10-2008, 02:12 PM   #5
burning bullet
So no one has anything to say????? no help!
Old 06-10-2008, 02:17 PM   #6
royo
royo's Avatar
Kool truck as for help you doing a fine job from what i see. good luck with it
nickle and dime
royo is offline   Reply With Quote
Old 06-10-2008, 04:15 PM   #7
kcjones
I wish I was a cowboy
kcjones's Avatar
Tough call on which rear to go with -- the shorty is great for the 400 RWHP, but requires wheels/tires/tub job/suspension mods to handle it. If you're racing, go with the shorty. If you wanna go fast but drive it every day, my very humble opinion is stick with the stock posi setup to relieve yourself of all the mods and work required with the short rear.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 06-10-2008, 05:05 PM   #8
scotts62
One day...
scotts62's Avatar
Yep
Scott
93 crew cab build
Project 62
Old 06-10-2008, 05:18 PM   #9
Slmd92DIME
Slmd92DIME's Avatar
good luck looks like a really good start.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 06-10-2008, 05:21 PM   #10
burning bullet
Thanks! thats all i rly needed to know. If I was to go with the short rear end where shuld I get parts for it like the other brakets and links that weld to the frame
Old 06-10-2008, 05:35 PM   #11
kcjones
kcjones's Avatar
Performance Online has some kits for rear suspension, including some 4 link stuff. You may have to have some of it custom built, though.
-Kris
Old 06-10-2008, 05:53 PM   #12
scotts62
One day...
scotts62's Avatar
Try ***************** for the weld in brackets, they are pretty reasonable, and you can get alot of axle tabs n things for what you are probably needing.
Scott
93 crew cab build
Project 62
