Old 06-04-2008, 01:52 PM   #1
SWILL
Wheel Question
Can a aluminum rim that has been sandblasted be restored to a nice shine ? Its basically a dull grey now, can it be restored to have that nice mirror shine ? How much work/money could a person expect ? Just wanted some opinions before I make a purchase. Thanks
shane
SWILL is offline   Reply With Quote
Old 06-04-2008, 02:11 PM   #2
raggedjim
raggedjim's Avatar
Re: Wheel Question
With a LOT of work anything can be shined ( my son is tumbling rocks in the garage as I write this) If he can polish rocks, you can polish those wheels!
It would be a lot of work but it can be done.
Rg
raggedjim is offline   Reply With Quote
Old 06-04-2008, 02:22 PM   #3
SWILL
Re: Wheel Question
Just get some compounds and a buffing wheel along with a little elbow grease and it should be doable ?
Old 06-04-2008, 02:27 PM   #4
mahanian
C10 addict
mahanian's Avatar
Re: Wheel Question
It can be done, it's just a time consuming process. You have to sand it and then polish it. I would start with 120 grit, then 220, finally 320. Be sure not to sand away any curvature or features in the wheel. Each time you switch grit, you sand 90 degrees to the previous sanding to remove the previous grit sanding scratches. After 320 grit, clean it well then you will polish it with tripoli compound, clean it again and polish it with white compound. Clean off the residue and now it should be nice and shiney. You can leave it like this or clear coat over the top. Hope that helps...
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 06-04-2008, 02:30 PM   #5
c10addict
c10addict's Avatar
Re: Wheel Question
lots of wet sanding... Depending on how bad the finish is depends on how heavy of a grit you start with... Sand blasting is way too agressive!
Try this link...
http://www.englishcustompolishing.co...aluminum1.html
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 06-04-2008, 03:15 PM   #6
SWILL
Re: Wheel Question
Thanks for the response. Im gonna go and check them out and see what im dealing with. I know he sandblasted them cause he planned on powder coating them ?? Wish he wouldnt have. Ive been looking for these wheels in an 8 lug and they have been hard to come by. Might just try it for the experience anyways !
