'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
trailing arms
Are the 3/4 ton & 1/2 ton trailing arms the same?
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
Re: trailing arms
The 3/4 ton arms have a plate welded to them for strength, but other than that they are the same.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: trailing arms
LWB and SWB are the same. As for 1/2 ton and 3/4 ton...I think....the 3/4 ton trailing arms are reinforced more then the 1/2 ton trailing arms. It's early yet, I'm sure someone will chime in on this.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 06-04-2008 at 06:51 PM. |
#4 | |
Re: trailing arms
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Re: trailing arms
I'm surprised, you should see how slow my computer is running.
Re: trailing arms
All trailing arms are the same, (blazer{2wdof course}, truck, 1/2, 3/4 and subs) clear back into 60's. I pulled a set off of a 64,5,6 ish looking 3/4 ton truck and they are the same with the exception of the reinforcement plates. Now keep it quiet, it's our little secret as the plates make the flimsy trailing arms pretty rigid and I can pull em for $20-30 a set around here as they are just big truck parts!!
#7 | |
VA72C10
![]() Join Date: Mar 2008
Re: trailing arms
its all about the +6 inches
Re: trailing arms
they stopped having coils at the end of 72, so yeah.
