Old 06-04-2008, 07:33 PM   #1
Ackattack
Ackattack's Avatar
ls1 camaro/firebird electric fans
I have an opportunity to buy a set of electric fans from a LS1 camaro fairly cheap and I'm considering using them on my 68. Does anyone know how well they fit, or has anyone done this? Post pictures or other info if you know.
Ackattack is offline   Reply With Quote
Old 06-04-2008, 08:25 PM   #2
pcmcobra
pcmcobra's Avatar
Re: ls1 camaro/firebird electric fans
I put a set on my 86, fit really good...
Just bought some angle aluminum from metals depot and some nuts and bolts from home depot. I think I have $75 in mine.
I went with a vsc controller, but I am changing that now that I have my 6.0 in and let the pcm control them.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-05-2008, 04:25 PM   #3
shifty
Questionable
shifty's Avatar
it truly depends on what year car you buy from.
i picked up some from a 94-97 (whatever the year range is before 98-02) and they didn't fit as good as the ones you see pictured. i also tried the 94-96 Impala fans which were better, but not by much. i prefer the look/feel of the setup i got on mine (i did a writeup in the FAQ forum)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-05-2008, 05:46 PM   #4
Rokcrln
Rokcrln's Avatar
Here is what I have in LowBuck but I do not remember what yr thay are out of. What I like better about these from the ones above is they allow for pass through air see the cut outs. They are supose to have rubber flaps over them so when sittinf still they are colsed and the fans suck 100% from the radiator but when at speed they open and allow extra air to flow. I made simple brackets that let the fans simply slide down into the bracket and then the SS on top of the radiator hold it in place. I have driven this truck over 7k miles now in everything from back country road to California's bay area traffic and never a heating problem.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-05-2008, 06:08 PM   #5
Sicmaro
Always wrenching!!
Sicmaro's Avatar
i have ls1 fans on mine, they fit pretty good.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 06-05-2008, 10:48 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
not sure about the fit as they may be too long...but I liked the '05up GM truck fans I put on my '01 Sierra C3
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
