06-04-2008, 10:46 PM | #1 |
47 ri 59 4x4
I have a question has anyone put 4x4 axels under a 47 to 59 Chevy truck
what did it involve and what steering box did you use to get good power steering Gene Sharp |
06-05-2008, 09:21 AM | #2 | |
Re: 47 ri 59 4x4
Napco did a few conversions in the later model trucks. Most people are swapping frames. I've seen those body styles on K5 frames, to convert to 4wd, get a stronger frame and power steering. Last edited by FormerMember; 06-05-2008 at 09:21 AM. |
06-05-2008, 01:23 PM | #3 |
Re: 47 ri 59 4x4
I have two pickups with later model frames and 4x4
have a couple of others and wanting to try it a different way Iknow the Napco trucks had 4x4 acels added does anyone know or a good steeriing box to use when using stock frame Gene Sharp |
06-08-2008, 10:15 PM | #4 |
Everything is work in progress
Re: 47 ri 59 4x4
Gene post a few pics and we can help you out better. If your wanting to convert to power steering you can throw a hydro-boost on there at the same time and have power brakes and steering, a major bonus.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 06-08-2008 at 10:17 PM. |
06-09-2008, 09:21 AM | #5 |
Re: 47 ri 59 4x4
I think CPP has a set of weld on plates for a normal Chevy style Saginaw steering box.
06-09-2008, 01:16 PM | #6 |
Re: 47 ri 59 4x4
Grendel, don't mean to hi-jack.. but is your username because of the 6.5 grendel cartridge?
my reccomendation would to (hopefully not being too obvious) use 1-ton axles. if you're serious about offroading it, i'd suggest high-steer arms. the power steering box from 67+ 4X4 trucks should work fine for you if you have the correct place to put it (if your body mounts or other don't get in the way) and a steering box from a 2WD 67+ will work if you do use high-steer mounting the steering box shouldn't be too much of a problem.
RN U OVR |
06-09-2008, 01:19 PM | #7 | |
Re: 47 ri 59 4x4
I do agree, that considering you have to fab something up, I'd start off with at least cross over steering and stay away from a 4x4 push pull steering set up that Chevy loved so much. |
