Old 06-04-2008, 11:06 PM   #1
tkeduk8r
tkeduk8r's Avatar
I can't get my AM/FM radio to work cept at idle...
soooo thinking it could be voltage regulator, I checked the charging voltage at the battery and WHOLLY SMOKES 16.4 volts. (no wonder my lights have been so bright)... so I replaced the voltage regulator with a good spare I had laying around and I STILL have the same result... 16.4 volts and my radio still wont work... so I pulled my radio and tested it on my test bench and It works as long as the voltage doesnt exceed 13.6 volts.... sooooo.... next I took my voltage at the fuse block and sure enough 16.4 volts...
Anyone else have this issue???? I have seen and read plenty about not having enough charging voltage, but nothing about too much.... any ideas????
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 06-05-2008, 07:13 AM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: I can't get my AM/FM radio to work cept at idle...
I had an 85 Dodge truck that one night I went out to start it and when I turned on the lights it was like flash bulbs going off. The radio started smoking...tail lights went real bright and then blew...dash lights went crazy...but the truck was running. Weird thing was I had 11.64 at the battery. Didnt go any further into checking what was going on. I just decided to junk that troublesome truck.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-05-2008, 12:52 PM   #3
tkeduk8r
tkeduk8r's Avatar
This one I cant junk... its my bb 72 Super ... just wierd why I would get 16 volts at the battery and fuse box with two different v-regulators... im just afraid Ill hurt the tach or some of the other electrical componenets with that kind of voltage....any body else have any experience????
--Mike
Old 06-05-2008, 05:19 PM   #4
powell72
powell72's Avatar
Could it be the battery? Do you have another to try?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 06-05-2008, 06:34 PM   #5
berencam
berencam's Avatar
i had voltage issues so i changed out the voltage regulator with the high dollar one, and i still had issues. so i took it back and got the cheeper one and wala no problems with voltage.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
