Old 06-05-2008, 03:10 AM   #1
71shortwide
71shortwide's Avatar
Rear brake question?
i need to replace my brakes on my 12 bolt but i really want to go to disc. I have searched around and havnt had much luck, what is my best options? Any help would be greatly appreciated. thanks
Justin
71shortwide is offline   Reply With Quote
Old 06-05-2008, 11:13 AM   #2
Curbstone Mech
Active Member
Re: Rear brake question?
There are a couple of board memebers that make rear brake disc kits.I would start there. I can tell you a company NOT to use... Master Power Brake, they're jerks. PM me if you want the low down. If you're not looking for the " look" of rear discs, or if you're running a closed wheel, Praise Dino Brake makes a rear drum upgrade that outperforms my rear discs. They use a bigger drum, bigger wheel cylinders and bigger shoes. I think the kit cost me 4-$500.
They have excellent communications and back up their products. Good luck
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 06-05-2008, 11:42 AM   #3
71shortwide
iam goin to try for a open wheel but things change you know haha. may be some people that make the kits will chime in, i seen one but he said he was out of brackets thanks
Justin
Old 06-05-2008, 10:41 PM   #4
71shortwide
hmmm i have looked every wear or a 12 bolt disc brake kit and havnt had any luck. what am i missing? thanks
Justin
