06-05-2008, 03:11 PM | #1 |
Need some rear suspension advice
I am finally digging into my 71 and starting with the rear. I allready have a set of CPP rear trailing arms and the CPP rear notch kit and slam specialties RE7's. Not trying to lay frame but I know it will get pretty low with a standard c notch so I want to get an adjustable panhard bar and prob do the shock relocation as well. My question is who makes the best panhard bar? What shocks are the best to use? I was planning on going with ECE for the panhard bar and using Beltech nitro shocks. Also, do you guys think a crossmember replacement is needed? If so, who's should I go with, brother's has one, cpp has one and so does ECE. Also, since I know someone will catch it, I will be converting from lwb to swb (hence the crossmember question).
71 LWB c10- needs more work than I have money! ASE certified Ford Master Tech Last edited by fastazhell; 06-05-2008 at 03:15 PM. Reason: addl info |
06-05-2008, 04:26 PM | #2 |
Farm Truck
Re: Need some rear suspension advice
Brother's make's one?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
06-05-2008, 04:52 PM | #3 |
I am a Referee of life.
Persoonally I would try to buy all same brand/manufacturer parts.They tend to be engineered to fit together.I don't think much of modern engineers but I figure they leave enough clearance to keep stuff from rubbing against each other.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-05-2008, 09:42 PM | #4 |
i just got an ECE rear drop kit service was good parts are fantastic well built, dealt with cpp service was crappy parts ok, i agree with PanelDeland buy all from same company because each companies' parts works only with there parts becomes hassle to mate different companies parts to make it work thats my .02
06-06-2008, 04:54 PM | #5 |
thats what I was thinking about mixing companies...I actually picked my trailing arms up off ebay NIB from a private seller for a great deal. So i haven't actually had to deal with cpp for anything yet, customer service wise anyway. thanks for the input.
71 LWB c10- needs more work than I have money! ASE certified Ford Master Tech |
06-06-2008, 05:00 PM | #6 |
Tasty Cakes!
I bought my shock kit and super track bar from ECE. Great guys. Haven't installed it yet, but plenty of other ppl on this site have.
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
