Old 06-05-2008, 03:46 PM   #1
mhicks
mhicks's Avatar
Distributor Selection Feedback
What kind of HEI distributor do you like. I am in the market for a new distributor. I have about $200.00 to spend. What would you recomend and why. It will be going in a stock 290 HP crate motor with 600 CFM edlebrock carb. with edelbrock intake and headers. '73 Chevy half ton.
Thanks,
Mike
mhicks is offline   Reply With Quote
Old 06-05-2008, 03:52 PM   #2
beaterC10
Re: Distributor Selection Feedback
I would look for a GM ZZ4 distributor. It has a nice curve and is real reliable. I found mine on Ebay for around $100. I have looked at some of the aftermarket distrubutors and wasn't impressed with the made in China quality.
beaterC10 is offline   Reply With Quote
Old 06-05-2008, 04:51 PM   #3
mhicks
mhicks's Avatar
So this is made by GM? I think it would be nice to have one so if there was a breakdown any auto parts store would have the parts in stock.
Old 06-05-2008, 11:54 PM   #4
Billy81
Billy81's Avatar
I agree i bought one of those aftermarket distributors on Ebay and the coil went out in mine after one week.
Billy81 is offline   Reply With Quote
Old 06-06-2008, 12:37 AM   #5
Pyrotechnic
Pyrotechnic's Avatar
I run an MSD Streetfire HEI and it's been good to me so far. It's MSD's budget line for those who can't afford a Pro Billet but still want a quality part. They state that they use the same drive gear on it as the higher end distributors.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 06-06-2008, 07:23 AM   #6
mhicks
mhicks's Avatar
I ended up buying a MSD Spitfire for $188.00. I know to set the timing to about 10 degrees with the vacuum advance disconnected but when it comes to setting the adjustable advance in the distributor with the allen wrench how is that done or where does it need to be set at?
Old 06-06-2008, 10:29 AM   #7
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
The way I do timing on carbed engines is I set the initial, then I set the centrifugal (on WOT runs, vacuum advance disconnected), and only after that I play with the vacuum so that I get the most advance without pinging under load. Read here for some baseline settings for an HEI dizzy:
http://www.73-87.com/7387garage/drivetrain/hei.htm
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 06-06-2008, 11:45 AM   #8
LONGHAIR
Centrifugal advance assy. on the HEI is pretty darned good. The stock weights and advance plate are perfectly acceptable for all but the highest HP/RPM engines. ALL stock HEIs that were installed in V8s are designed to have a total centrifugal advance of 20 degrees, +-1 degree due to production line tolerances. This is as measured at the crankshaft (10 at the cam).
This statement from the link above is not entirely true. The distributors from the early emissions era have a lot more. They ran with "ported vacuum" and very late initial timing. This meant that they had to have more centrifugal advance built into them so that they could get to the 34-36 degrees needed at higher RPM. They are not all the same. You have to know what you are working with and adjust accordingly. This is the reason that I always caution people against "just switching" their vacuum advance unit's source. I do believe that you need to be running with "full" manifold vacuum, but you can't just go "messing around".
LONGHAIR is offline   Reply With Quote
Old 02-28-2010, 11:03 PM   #9
pa_snowman
anyone rebuild a stock hei....replacd the flyweight bushings? not switched over to the recurve kit but just refreshed the stock setup?
jim gallagher
pa_snowman is offline   Reply With Quote
