11-07-2002, 06:54 PM | #1 |
Torque Converter Bolt Pattern
I want to install a higher stall torque converter in my 71' C20, with it's original TH350 transmission. I see there are apparently two different bolt patterns, small and large. I wanted to buy the converter before I pulled the transmission what size should it take. Or, could it be either one and I won't know until I pull the tranny?
11-07-2002, 07:11 PM | #2 |
Fabricate till you "puke"
The trucks have a 168 tooth flex plate(14" dia if stock). as a rule, this flex plate will take either converter (2 patterns). The 350t's as a rule have the small pattern,as do most aftermarket high stall converters......you should be in good shape.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-07-2002, 07:21 PM | #3 |
Well, you could do a little math and figure out what the bolt pattern is. Take your inspection plate off, and get a rough estimate of the diameterof your flex-plate. Then measure the distance between the edge of the flex plate to the weld nut on the converter for one weld nut. If one isn't visible you'll either have to turn the engine with the tranny in N, or have someone bounce the starter until one is visible.
Once you get that measurement assume your weld nut is probably something like 9/16" - 3/4" wide, and then subtract 1/2 of that + the measurement you made earlier from 1/2 of the diameter of the flex plate. That will tell you the distance from the center to the hole for the converter for one weld nut. There's three of them, so what you end up with is an equilateral triangle between all three mount points. That given the diameter of the flex plate, and the distance from the edge of the flex plate to the mounting holes is all you need.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
11-07-2002, 08:20 PM | #4 |
you could count the teeth.....but that would make me insane(Im already crazy). Take a took at the starter, if the bolts are staggered, its a 168 T wheel(14" dia). If the bolts are straight across , it a 153 T wheel (12 3/4" dia"). just drop the inspct cover, & check if you have another set of holes in the flex plate that arent being used......
11-07-2002, 08:27 PM | #5 |
CCRider
Take a good look at your flexplate, a lot of them are drilled for both patterns
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
11-07-2002, 10:05 PM | #6 |
you dont need to worry about patterns, both are in the wheel you have, youll be fine, go ahead and get the converter,
good luck |
