Old 06-05-2008, 10:15 PM   #1
qksilver
LWB bed on a 3500 cab and chassis
Bought a 88 3500 commercial dually truck with a huge utility bed on it. Sold the utility bed and want to make it a pickup.
Did some measuring and the wheels look like they would only stick out a little.
Has anybody put on a regular pickup bed on a commercial dually cab and chassis?
Pix?
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 06-06-2008, 08:12 AM   #2
slug
slug's Avatar
Re: LWB bed on a 3500 cab and chassis
does the truck have dual rear wheels, if so, you may have trouble with the wheel wells not being wide enough
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 06-06-2008, 08:51 AM   #3
qksilver
yes it does but not like a factory dually pickup.
They only seem to be about 3 inches per side wider. I was thinking of using flexible rubber flares.
Old 06-06-2008, 09:58 AM   #4
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
So is that one of those narrow-dually trucks? As in, if you compare it to a regular dually truck, yours ain't anywhere near as wide in the rear? Those require wider wheel tubs in the bed, for the outside you can use some offroad fender flares and it will work good, but tis the inboard wheels that will mess you up. Still tho, nothing a torch/sawzall and a welder can't take care of.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 06-06-2008, 01:52 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
What Ivan said... You are going to have to modify the inner tub for full travel...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-06-2008, 07:44 PM   #6
qksilver
thats what i was afraid of..........
