Retired Air Force Veteran
![]() Join Date: Aug 2007
Transmission dust shield
Is the transmission dust shield for a turbo 350 and turbo 400 the same? Thanks
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Little help please? Thanks.
1FINE69
Re: Transmission dust shield
No. they are different and you have to watch out for the pontiac versions with a starter on the opposite side.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
1FINE69
Check a catalog and they will show you different part #s. National parts depot or a board vendor should be able to tell you more about it.
The Engine Whisperer
TH350 and TH400 use the same inspection cover.
![]() Join Date: Jan 2000
Chevy T350/T400 same cover. Don't know about the BOP ones.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
Thanks for the info guys. I'm still confused. One guy says different and 2 others say the same. Here's a pic of the cover I'm asking about. Thanks.
The covers are different as the TH 400 cover has a different hole spacing on one side. Attached is a picture of a TH 400 cover, (in front) and a TH 350 cover (in the rear). The TH 400 cover has pointed ears on both sides but the TH 350 has only one pointed ear.
You could probably redrill the transmission to make the TH 350 cover fit a 400 but I have never tried it. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#9 | |
Jim, Thanks for confirming this. Thanks for the pics.
