Anyone running a Weiand Intake..
With a QJet?
I am considering a Weiand 8004 Action Plus Intake or an Edelbrock 2101 Performer instead of the cast Iron stock for a little better performance and hopefully mileage. Are they essentially the same type Manifold? Anyhelp would be helpfull. Thanks Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
I have a radical idea!
Re: Anyone running a Weiand Intake..
You should get a little more performance out of either, but in my experience, I doubt you'll see a mileage increase. Bigger plenums and runners typically use more fuel.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Chevy nut
This will be the only time I will have to disagree with you man! I had a complete performer package on my 350 I had in my 77 SS El Camino. Cam, intake and carb. I also had Hooker super comps and duals with glass packs. I was able to go 311 miles on 3/4 of a tank. Before I swapped everything out....I was lucky to go 200 miles on a full tank. I guess doing a full package and tuning everything right you can get mileage. Now I dont know if I could do the same with one of our trucks...but you should be able to get a little better mileage.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" Last edited by caminokid; 06-06-2008 at 08:03 AM. |
I have never noticed any power or economy benifits from just an aluminium manifold change. The two manifolds your talking about are basicaly just coppies of a stock chevy manifold. They will give a bit more power at rpms over 2500rpm, but not realy noticeable in the seat of your pants. When you change cam, manifold and carb, its more likely the cam that gives you more economy and power. An aliminium manifold did give me better cold drivabilty, and alow me to have the choke come off sooner. For better economy with just a manifold change you can rejet the carb and play around with the adjustable power valve in a Q jet.
i choose the weiand over the edlebrock , i like the looks of the weiand better.
70 c10 stepside ,350v8, m-20 4 speed ![]() |
I had a Weiand 8004 once and I liked it alot. I generally like the look of the Performer better, but I think the Weiand makes better torque. As far as better performance, i've always noticed more with aluminum intakes over stock.
#7 | |
Don't hesitate to disagree with me. I sometimes argue with myself! ![]() ![]()
#8 | |
Chevy nut
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
#9 | |
![]() *Please don't refuse to sell me that bumper now!! ![]() ![]()
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 06-06-2008 at 09:40 PM. |
caminokid, did you remove the cat at the same time?
Chevy nut
I had duals on it. When I got it the motor trans and exhaust was gone. I dont believe in cats.
#12 | |
Chevy nut
