06-06-2008, 12:32 AM | #1 |
72 core support on a 68?
I was tearing into my 68 today and noticed that my core support was gone and I was wondering if a 72 support would work and what mods if needed would need to be done since i have acouple laying around. Thanks for the help.
ASE MASTER TECH
06-06-2008, 12:52 AM | #2 |
Re: 72 core support on a 68?
It will bolt in... but your headlight buckets won't be in the correct place. It's 67-68 & 69-72 for chevrolets.... GMC's are all the same I think... (you'll have to double check me on the GMC's)
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
06-06-2008, 12:56 AM | #3 |
oh i forgot to tell ya'll its a chevy. thanks for the help
ASE MASTER TECH
06-06-2008, 10:22 AM | #4 |
72 core support is the same as 68 if you remove the added buckets for the 72. But you will have to add the holes for the headlight adjustments and spring and may have massage the are around the light opening. Get them close to each other and you can see what need to have happen for the lights.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
06-06-2008, 10:42 AM | #5 |
Yeah. you can MAKE it work if you are determined and willing to work at it.
One other thing is the 72 support won't have the tapped holes to mount the 68 splash guard. I've seen trucks without the guard before so it's not a big deal. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
06-06-2008, 10:56 AM | #6 |
ok thanks for all the help i also have a 69 gmc support thats rust free, but really didn't want to cut it up, but would it work better than the 72 chevy support?
ASE MASTER TECH
06-06-2008, 11:14 AM | #7 |
I think either one would be about the same amount of work... Both have buckets that would need to be removed. I can't think of any reason why one would be easier than the other except the gmc may have more spotwelds to remove the buckets.
Good luck, Rg
06-06-2008, 01:53 PM | #8 |
thanks for the help
ASE MASTER TECH
