06-06-2008, 09:54 AM | #1 |
6 inch drop on 67
I want to drop my 67 4 1/2 in front and 6 inches in the back.I have the drop spindles,coils,shocks for the front,and the drop coils/shocks, and ECC super panhard bar and shock relocators for the back. Is there any thing I am missing or any concerns/problems I may encounter before I start.Thanks in advance
06-06-2008, 11:45 AM | #2 |
Re: 6 inch drop on 67
Sounds like you have it covered. Some people run a c-notch with a 6" drop but I haven't had a problem yet without one.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
06-06-2008, 11:48 AM | #3 |
VA72C10
Sounds like a complete list, from what i've read you won't need a c-notch. But i have heard that you might hit the bumpstops on large bumps and if you plan on loading up the bed it might bottom out on you.
06-06-2008, 09:37 PM | #4 |
Tot Roddin'
Just like mentioned above, but it sounds like you have all the bases covered. lolife99 is running this setup on his Blazer, and hasn't ran across any issues yet. This is actually the same setup I plan on running on my '72.
Good luck with the install, but remember.................... we love pics!!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 06-06-2008 at 09:38 PM. |
