Old 06-06-2008, 03:21 PM   #1
hdrider
timing ???
what is the timing specs. for a 1982 GMC 5.0 4bbl...thanks
hdrider is offline   Reply With Quote
Old 06-06-2008, 06:08 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: timing ???
My 1983 sticker says 4 degrees, idle speed 500 rpm in D, fast idle at 1600.
Haynes manual for 1982 says look at the sticker.
For more info, read Billla's informative ignition timing FAQ.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 06-06-2008, 07:08 PM   #3
hdrider
Re: timing ???
thanks...but im getting conflicting info...one source told me 8 to 12 deg. adavanced
Old 06-06-2008, 07:17 PM   #4
hdrider
Re: timing ???
ok..got it..sticker on my truck says the same...is that with the vac. advance hose on or off...???.......thanks
Old 06-06-2008, 08:24 PM   #5
LONGHAIR
Re: timing ???
If everything is stock....go with the sticker.
That would have a distributor that is calibrated for "ported" vacuum advance. The 4 degree setting is the factory specification. Even though there is not supposed to be any vacuum to the distributor at idle, (in a ported configuration) I would still disconnect it and plug the line when setting the timing.
8-12 is for distributors calibrated for "full" manifold vacuum.
LONGHAIR is offline   Reply With Quote
Old 06-06-2008, 08:30 PM   #6
hdrider
Re: timing ???
thanks much guys...been a while since ive had my head under a hood...gettin a bit rusty i guess.........tks!!!
Old 06-06-2008, 09:51 PM   #7
PhilaTruck
PhilaTruck's Avatar
Re: timing ???
Glad you asked, glad to help.
Subscribe here!
