![]() Join Date: Apr 2008
What to use
I have a 67 c10 .I have a complete ft suspension from a 87 c10 upper controls arms/lowers/spindles/rotors/and all steering components.I am planning on using the steering from the 87.I am going to buy drop spindles to lower the front should I use the 87 setup and get spindles for that or just use the 67 and get spindles for that?Its getting torn apart either way for cleaning/paint.Has anyone had any fitment problems with the 73-87 setup?
I am a Referee of life.
Re: What to use
Use all 87 stuff would be my opinion.From reading here,it's cheaper,more readily available, and will fit what you got.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: What to use
74 and up use a different control arm bushing that is thought to be better by some, so a complete swap would be better, the 67 stuff is kinda small (tie rods and ball joints) are not very thick, so the 87 stuff is more durable.
Chevy nut
Re: What to use
Here is my thread where I used everything from a 87.
http://67-72chevytrucks.com/vboard/s...d.php?t=292762 Have any questions..ask away!
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" Last edited by caminokid; 06-06-2008 at 08:23 PM. |
Re: What to use
Caminokid did you have any problems with header fitment?Im planing on rebuilding the 350 and 700r4 from the 87
Chevy nut
Re: What to use
I sat my 350 down on the frame and check my header clearance. It all fit just like it did on my 69.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
