Old 06-06-2008, 06:24 PM   #1
gmc67swb
gmc67swb's Avatar
another question on disc brakes
Swapping over to disc on the front,The question i have is,on my 67 gmc truck can i use the upper and lower control arms on the truck are do they need to be replaced? The reason i ask is all ball joints and bushing are only 2 years old. I Have a 72 front disc set up as the replacement. I figured if i could swap spindals for now then build up the other arms for the future. Any help on this is appreciated.....thanks
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 06-06-2008, 06:30 PM   #2
powell72
powell72's Avatar
Re: another question on disc brakes
Sorry, but disc brake (71/72) spindles have different ball joints then 70 and older drum trucks.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 06-06-2008, 06:46 PM   #3
gmc67swb
gmc67swb's Avatar
So if i swap ball joints then can i use the orginal control arms?
Old 06-06-2008, 06:49 PM   #4
70rs/ss
70rs/ss's Avatar
Yep, 67 A-arms and 72 spindles with the right ball joints. I am not sure, but the upper might be the same, but lower is for sure different.
70rs/ss is offline   Reply With Quote
Old 06-06-2008, 07:21 PM   #5
arkracing
Weekend Warrior
The steering stop on the lower is differant - you would have to modify it to work properly.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 06-06-2008, 07:59 PM   #6
Super-Dave
Super-Dave's Avatar
I just did mine with 88 3/4 ton gear and used 73 upper and lower ball joints on my 68 arms. also had to use the 88 steering parts.
Super-Dave is offline   Reply With Quote
Old 06-06-2008, 11:55 PM   #7
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Super-Dave,
Is your truck parked at Vandenberg?
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 06-07-2008, 07:14 AM   #8
gmc67swb
gmc67swb's Avatar
I have all the linkage off the 72 so if i swap it i should be good to go (right)and thanks for all the input,you guys and this form are great seems like i always find someone out there that knows what to do. again thanks ......
Old 06-07-2008, 10:45 AM   #9
powell72
powell72's Avatar
If all the parts off the 72 are in good condition I'd just swap all the 72 stuff over to yours.
Chris
Old 06-08-2008, 01:09 AM   #10
ChevyDude
Thats what I did on my 68'. Found a complete 71' front crossmember...cleaned it all up and bolted it to my 68' frame, disc brakes.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
