Old 06-06-2008, 10:34 PM   #1
colin_havens
colin_havens's Avatar
Redoing the rear bag setup.
Ok, I am wanting to redo my rear set up, and then later z my front to lay my truck out. Like anyone, once you get started, you are only satisfied for a little while. Let me start with what I currently have. The back is bagged on the stock 2link with a bolt in notch and adj. panhard bar from CCP. I want to get the truck on down where it will lay frame i the rear. Im running 20s all around, with 275/45 rubber on it--tires are 29 inches tall, so I can eventually move up to 22s
Now, I know I will need a bigger notch. KP has one for our trucks, and actually so does suicidedoors. Both fit the crooked ass frame we have on these trucks. I know that the one from suicude doors is a little cheaper. It is a 16 piece kit though.
My questions:
--How many pieces is the KP notch? I would rather use a notch that was not a ton of pieces. Just to save time on welding and grinding to make it all purdy
--I want to run a triangulated 4 link with the bags on the bars. Something like this:http://www.*****************/SuperLliftWishboneKit.php
or this http://www.*****************/SuperLif...d4-LinkKit.php
My question is does anyone have experience with either of these setups, and how long were your bars? Or should i jus tnotch it out and relocate my bags over the axel and use the stock 2 link?
--Also, my truck has a one piece driveshaft, and is a shortbed. I have been told you have to run a 2 piece or tunnel the cab. I dont want a body drop or anything, so is this really necessary?
Thanks for the help in advance guys. I know that I will get some great ideas from the members on here. Also, pics are a plus if you have them!
colin_havens is offline   Reply With Quote
Old 06-06-2008, 11:56 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: Redoing the rear bag setup.
I can vouch for the KP notch: Great product and it's an 8pc.
Frizzle Fry is offline   Reply With Quote
Old 06-07-2008, 12:10 AM   #3
GRIMSS
GRIMSS's Avatar
TTT
This is what I've heard. You want the bars the longest you can fit. Most mini's have them to the rear of the cab. I'm planing on running the same kit on my panel when I get to working on it.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 06-07-2008, 12:05 PM   #4
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I built my notch so I can't help you there. And, I don't have a motor/trans in yet either I do have the S/D superlift triangulated four-link on mine. I'd have to measure my bars, I don't remember how long I ordered them. GRIMSS is right on the length, get the longest that will fit, that'll give you less pinion angle change through the range of motion. Here's mine installed(I will be changing a few things but it'll give you an idea nyhow)
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-08-2008, 01:18 AM   #5
colin_havens
looks good. I am curious as to why you ran the bars with the bags on them on the inside of the axel instead of outside. Also, will you have to tunnel your cab? i still am wondering if I will have to do that for my one piece axel.
Old 06-08-2008, 09:06 AM   #6
GRIMSS
GRIMSS's Avatar
most mount the bars inside for wheel and tire clearance. My guess is yes he'll have to tunnel the cab.
**I like the wire mounted valves
2001 GMC SIERRA
1968 Camaro
Jared
Old 06-08-2008, 10:51 AM   #7
colin_havens
does anyone have pics of how much the cab had to be cut? I just want to know what im getting into. Can I keep my in cab tank with this tunnel, or will I have to move it?
Old 06-08-2008, 03:05 PM   #8
Frizzle Fry
When I went from 127" to 115" (burb to tahoe) I switched from a 2-piece to a 1-piece. Then I notched the rear and ended up needing to tunnel the floor. But mine's different than a truck cab (that's why I didn't comment earlier). I will say this though; If I were to build a truck with a big notch I'd prefer a 2-piece over the single.
Old 06-09-2008, 01:43 PM   #9
BACKYARD88
BACKYARD88's Avatar
I plan to narrow the rear so I mounted the bars inside for plenty of clearance. I haven't gotten to the driveshaft part yet but I'd imagine I'll have to tunnel the cab some. If you have to tunnel more than an inch or so the in cab tank will have to go.
-Mike Owen-
Old 06-09-2008, 03:51 PM   #10
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I had a superlift 4 link from ssd. My bars were 36" and 38". I would order them about 32'" and 34" if I had to do it again. I had to notch my cab but not past the gas tank. It wasn't much of a notch really. Keep in mind when you build your rear setup that if your ever gonna Z it build it accordingly. I backhalfed mine and within a year i was Zing it. I then found out that my 1 piece driveshaft was going to hit the crossmember where my upper link bars attached to. So I put in a 2 piece.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-09-2008, 10:26 PM   #11
colin_havens
Im guessing that the outside square bars were the shorter bars, right? I am curious as to why you would do the shorter bars. I do plan on zing the front eventually, as the $$$ and wifes permission allow. lol how sad is that!
I am going to make a crossmember out of round tubing, with it notched out high enough for the driveshaft.
Do you have any pics of your setup? I would love to see it. Thanks for the info so far!!
Old 06-11-2008, 03:23 PM   #12
c10addict
c10addict's Avatar
I used the KP notch on my beater project... GREAT product! Worth the $$$ if you dont want to fab something up...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 06-11-2008, 03:46 PM   #13
BACKYARD88
BACKYARD88's Avatar
I like that! Looks clean
-Mike Owen-
Old 06-11-2008, 10:08 PM   #14
colin_havens
that does look great! Can you lay full frame with that setup/
Old 06-11-2008, 10:35 PM   #15
BACKYARD88
BACKYARD88's Avatar
My uppers are 34" and the lowers(square ones) are 32". With those lengths I get almost no pinion angle change through the whole range of motion.
-Mike Owen-
Old 06-12-2008, 08:53 AM   #16
c10addict
c10addict's Avatar
Thanks! It will not lay frame the way it is set up now but the notch is big enough to set it up to do so...
Old 06-12-2008, 10:59 PM   #17
98L150
///Relaxed Atmosphere
98L150's Avatar
c10addict,
does the rear end of your truck layout or do the trailing arms hit the inside of the frame before that happens? if it doesn't lay out how far is from doing so?
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 06-13-2008, 08:08 AM   #18
c10addict
c10addict's Avatar
It does not lay out... There is a 29.74 tall tire on it and the bottom of the frame is 4.5 inches off the ground.. Thats a big tire though! The trailing arms are touching the frame and I have probably 4 inches left in the top of the notch....
Old 06-16-2008, 09:26 PM   #19
Frizzle Fry
Time for lowering blocks
Old 06-16-2008, 10:36 PM   #20
BACKYARD88
BACKYARD88's Avatar
-Mike Owen-
Old 06-17-2008, 07:45 AM   #21
c10addict
c10addict's Avatar
I have 2" CCP blocks in there now... Need to get some flat aluminum 1" stock and give it some more drop! I am ready to pull the trigger on z'ing the frame.. Any good links on exactly where to slice and dice?? I have been studying pics on here and think I have it figured out... Although backyard88 with his angle cut to move everything forward threw a new mix in the old Z...
Old 06-17-2008, 10:25 AM   #22
BACKYARD88
BACKYARD88's Avatar
I don't think it's super important where you cut it, just make sure it will clear the firewall Only dond side I've found to moving the suspension forward like I did is I have to modify my core support to clear the P/S gear. That's nothing compared to the crap I've already had to deal with
-Mike Owen-
