Old 06-06-2008, 11:19 PM   #1
MN Rooky
1971 4X4
MN Rooky's Avatar
Shock Replacement ????
I got a 2001 HD and I'm thinking its time to replace the front shocks. I crawled under the truck tonight and saw the control arms(?) resting on the bump stops on the frame (orangish/yellow rubber bumper attached to the frame). Or is this the way it is suppose to be?
Also, I was told that the inner tie rods are loose and need to be replaced. How difficult is this to do myself?
MN ROOKY
1971 Chevy 3/4 4X4, 4" lift, 33's
2001 Chevy 3/4 4X4 HD, 33's (Wife's Truck)
MN Rooky is offline   Reply With Quote
Old 06-07-2008, 11:46 AM   #2
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: Shock Replacement ????
It's normal for the bump stop to touch the control arm, they are sort of a progressive stop if you will. I don't find the inners too difficult. Assuming you have rack and pinion steering you will most likley need a special tool to get them off. It should be available at most any parts store.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
