Old 06-07-2008, 07:44 AM   #1
soba_03
soba_03's Avatar
Serpentine Belt setup
OK building a motor for the 68 C10. I'm considering runing a Serpentine set up on it. However I'm not running Air conditioning.
I've been through several of the junk yards and it seems like everything I'm seeing has A/C on it. I'm not quite sure how it would work if I didn't run A/C. It looks like I would need the A/C compressor pulley to make the Belt run correctly.
Anyone running this set up with out A/C? I would love to know what you pulled the set up off of and any pictures or advice you could give me would be great.
Thanks.....
soba_03 is offline   Reply With Quote
Old 06-07-2008, 08:18 AM   #2
STP67-72
STP67-72's Avatar
Re: Serpentine Belt setup
The 90 ish v-6 and v-8 are the same. I have some plain jane work trucks at work that just run a big idler that bolts in where compressor fits. I am sure GM sells them if you have to call them. You need to drill one hole in pass. head to mount main bracket. Also upper hose works best off of same 90'syehicle. Take used one for pattern for sure. The 77 ish p/s box are o-ring style like the serp.p/s hose.Or you will have to make a special hose. I used a 78-87 sqare body p/s pressure line.It fits best with inner fender. The suburban p/s hoses would not fit corectly that i had. Hope this helps.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 06-07-2008, 10:19 AM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
STP67-72 is correct- if you don't want the A/C compressor (yet)- trot on down to your local NAPA and get the "AC Delete Pully" for like 28 bucks and some change. Another thing you may need to consider is whether the donor truck has a smog pump down below the AC compressor. If it does- you'll need a idler pulley to take it's spot too. That one, however, is only available through the stealership for like 80 fricken dollars! (Go ahead- ask me how I know).
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 06-07-2008, 11:25 AM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
WE have the genuine GM A/C delete pullies and the smog pump delete pullies in stock. If interested. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-07-2008, 12:18 PM   #5
neonlarry
neonlarry's Avatar
You do not need a delete pulley for the smog pump. With the proper length belt and routing it will work fine without.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-07-2008, 02:20 PM   #6
cparman
sharp as a marble
I think NAPA sells an A/C compressor bypass? pulley. It is a pulley that bolts in place of the a/c compressor. I have installled a couple of these for customers who's compressor has locked up
cparman is offline   Reply With Quote
