Old 06-07-2008, 01:18 PM   #1
imnezrider
imnezrider's Avatar
driveshaft
So I disconnected the driveshaft while thinking of putting lowering blocks on the rear. I changed my mind and now there is about 1-2 inches between the end of the shaft and the u-joint. How do I hook it up???
imnezrider is offline   Reply With Quote
Old 06-07-2008, 02:23 PM   #2
chevy72blu
chevy72blu's Avatar
Re: driveshaft
Did you take anything else apart? Im kind of confused. Nothing should have changed. Slide the slip shaft into the back of your trans further than you need to, then bring it back slightly to bolt on the U-joint caps.
Am I missing something here?
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 06-07-2008, 03:54 PM   #3
imnezrider
imnezrider's Avatar
Re: driveshaft
"Did you take anything else apart?"
No...only loosened the spring u-bolts.
Old 06-07-2008, 04:55 PM   #4
imnezrider
imnezrider's Avatar
Re: driveshaft
Here's what I am talking about.
Old 06-07-2008, 05:01 PM   #5
Wreckless_71
Wreckless_71's Avatar
Re: driveshaft
just pull the slip shaft out of the tranny a little bit... That's the only thing that really could've moved...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 06-07-2008, 06:24 PM   #6
imnezrider
imnezrider's Avatar
Re: driveshaft
Ok, it seems "stuck", but I'll keep trying.
Old 06-07-2008, 06:35 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: driveshaft
pull hard. greasing it will help. (in the zerk fitting)
Old 06-07-2008, 08:00 PM   #8
imnezrider
imnezrider's Avatar
Re: driveshaft
Thanks for all the input!
Old 06-07-2008, 08:10 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: driveshaft
With the springs on top of the axle, you can't use lowering blocks. You have to get a flip kit and then notch the axle for clearance. I thought about doing that and decided I'm going to just use lowering shackles and remove some leaves off mine.
But, either way, you really didn't need to remove the drive shaft for lowering blocks. The drive shaft slip joint should have about 1 1/2 to 2 inches exposed after everything is bolted up (that's what mine has). If you feel that the gap is excessive, something else has shifted on you. I'd try and loosen the spring u bolts again and bolt the drive shaft up and see how it lines up.
68gmsee is offline   Reply With Quote
