Old 06-07-2008, 01:27 PM   #1
woodie70
woodie70's Avatar
5/8 ton gear ratios?
i was thinking about changing out my r&p to gain some drivability on the highway.... 70' 5/8 ton, 350, two bbl, 3 speed.... should be 3.73 from all my research... wondering if any of you have done this and have any suggestions.
was thinking 3.08 or 3.38.
i am in the process of building a 90 350 2 bolt now, all stock engine converted to carb.... if i do that and go 350 turbo for tranny would that warrant me choosing a certain ratio.. not building a hot rod, i just drive it every day for now. thanks chad
1970 c10,150k original... drivin, yet project
1982 jeep cj 7, amc 360,9" lift,35x15.5 swampers
2005 nissan xterra 4x4,old ladies.
woodie70 is offline   Reply With Quote
Old 06-07-2008, 05:13 PM   #2
Re: 5/8 ton gear ratios?
I`m not familiar with a 5/8t.Never heard of that.What axle do you have?You need to be sure about the exact ratio you have.What form of research did you do?The best research would be drain gear oil,pull cover and either count teeth of find the ratio stamped in the ring gear.You can go with any ratio with what you are doing.If you have a 1/2t/12-bo;t rear you can go with 3.08s.
Old 06-07-2008, 05:38 PM   #3
woodie70
woodie70's Avatar
i will pull cover and look... and as far as research it is various sites and specs i've found on the net.... never heard of 5/8 ton? 3/4 ton suspension in a half ton, 6 lug wheels, stoarge box in the bed? i'll look at mine to be sure on gears, but running a 235/75/15 @ 65mph i'm turning 3k. would like to improve milage and be able to run at least 70- 75. thats why i was thinking 3.08
Old 06-07-2008, 05:43 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
Never heard of the 5/8 either, at least not in these models. I've heard the 73-78 Chevy Big 10's and GMC Heavy Halfs referred to as 5/8 tons, but I don't think they existed in 67-72's. To have 3/4 suspension, it would have to have 8 lugs, unless it just has heavier springs. All regular 67-70 half tons had 6 lugs.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-07-2008, 05:46 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
A 1/2 ton would have the 6 lug wheels. If you went to a 3:08 gear, that would be your best bet. Also not aware of a 5/8 ton in these years.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-07-2008, 05:54 PM   #6
67_C-30
67_C-30's Avatar
Maybe that part of the Ultra Rare Cor... - nah, I'm not going to say it!
My trucks
Old 06-07-2008, 05:59 PM   #7
woodie70
woodie70's Avatar
ok now i'm confused! your telling me all 67 c10's have 6 lug pattern?
Old 06-07-2008, 06:20 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
every 60 - 70 1/2 ton GM truck (maybe even older) came stock with 6 lug wheels.
I've also never heard of 5/8 ton, nor seen anything in factory documentation.
A 1/2 ton with heavy springs, is still a half ton. The tool storage box on the side was an option in its self, not related to any packages at all.
Now, if it is a 1/2 ton with a 3speed tranny, then it would in fact have the 3.73 gearing unles opted otherwise.
A 3.08 IMO is a great gear. Gives you the freeway RPMs just a tick higher than an overdrive, and take off isn't nearly as bad as some would make you believe.
Old 06-07-2008, 06:42 PM   #9
woodie70
woodie70's Avatar
thanks on the 3.08 notes, thats what i was looking for. and i apologise for the 5/8 ton, i was mis informed. the truck is older than i am, but i'm getting there. thanks for the info, sorry for my ignorance
Old 06-07-2008, 06:53 PM   #10
Longhorn Man
no big deal. Sometimes someone joins with info we've never heard of, and it's real. But more likely, some one has been misinformed. Thats what this place is all about, learning. (on a lesser forrum you woulda been called an idiot, but we won't do that here... not till we get to know you!)
Old 06-07-2008, 06:59 PM   #11
woodie70
woodie70's Avatar
that's geat! i am an idiot thought, so i'll save u guys the trouble of figurin it out.
no thanks haven't had it long itchin to start on it... fundage is my biggest issue.
i also blew the head gasketon my amc 360 muddin... that's my first priority.
thinkin ahead.
Old 06-07-2008, 07:43 PM   #12
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
He's talking about the heavy half tons. My 69 camper special is like that.
Daily Driver
-2007 Chevy
-Dark Blue Metallic
-Regular Cab
-4.8 V8
-4x4
Ongoing, Never Ending, PITA, Love of my Life
-69 Chevy C/10, Camper Special
-350/TH400
-Loudest System on the Board
Pl4yboy is offline   Reply With Quote
Old 06-07-2008, 08:29 PM   #13
Yeah,I would never raz a guy for being misinformed.FYI,GM just never had such a designation.Even the later Heavy Halfs and Big Tens were still...cough cough...halfs and tens...sniff sniff.
Old 06-07-2008, 08:37 PM   #14
caminokid
Chevy nut
caminokid's Avatar
My 46 and 50 had 6 lugs with 16 inch wheels.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-07-2008, 10:09 PM   #15
Longhorn Man
You can call it that... But... GM never did.
Sweet.. more info!
Old 06-07-2008, 11:59 PM   #16
67_C-30
67_C-30's Avatar
You're working a '70 Chevy, so that makes you OK in my book. BTW, we love pics here, so cough 'em up!!
My trucks
