Old 06-07-2008, 06:25 PM   #1
myfirstcarwasa73trk
myfirstcarwasa73trk's Avatar
Won't Stay Running
I have a '67 Chevy pickup with a straight 6 out of an '81. Had problems with it running for 11 seconds, then dying. Bought new distributor and wires, and gave it pretty much a basic tune-up, still has same problem. Just need help figuring out what could be causing this, and if anyone knows how to fix it.
myfirstcarwasa73trk is offline   Reply With Quote
Old 06-07-2008, 06:59 PM   #2
old Chevy guy
old Chevy guy's Avatar
Re: Won't Stay Running
Ive had vehicles with fuel problems, such as plugged filter or stuck float that limits how much feul can get in so she runs till the bowl is empty then stalls .Then when bowl has a chance to fill again she runs again then stalls.When you shut it off theres still some residual fuel presure. On my 69 nova with an inline 6 the needle seat actually treaded out and held the float in a almost closed position at the bottem of the bowl. Just a thought if you already changed the electrical stuff.
old Chevy guy is offline   Reply With Quote
Old 06-07-2008, 07:22 PM   #3
myfirstcarwasa73trk
going to try to manually fill w/ fuel
Old 06-07-2008, 07:38 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you don't have luck with the fuel thing try checking the ignition module.I am assuming you have the HEI from the 81?You might also check to see if it was wired without the fuseable link.Check to see that while running the voltage at the distributor does not drop to between 7-9 volts.
BTW you can remove the ignition module and have it tested at your local APS.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-07-2008, 07:53 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Some questions and couple of things need to be checked.
1. When it runs, how long does it run (seconds or minutes)?
2. Does it run smooth?
3. Immediately after it stops running, does it still have spark?
4. And if so, is it getting fuel? (may have to have the breather off to see in the throat and manually activate the throttle link.)
Fuel and spark is the primary thing it needs as was mentioned. There's other things that it needs to run right and to stay running but that's where it all begins.
68gmsee is offline   Reply With Quote
