Old 06-07-2008, 11:10 PM   #1
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Anybody use wheel spacers?
Okay, so I wussed out on tire size for cost and rotational sake, and now I regret it! Unfortunatly, tire's are expensive, and uncle sam(my boss) is cheap. Soooo.. I want to push these babies out an inch or two.
I have stock 15x8 rallies with 255/60's, and look good on the front, but the rear has me left dissapointed.. Has anybody here used these with spacers, and if so, how have they worked out for you? How about the quality? Where did you get them?
If I get a new set of wheels, you can add the cost of divorce to them, so I think I will just stick with what I have, plus, I like my plain rallies. I'm a plain type of guy. I just want them to fill the wheelwells.
Any suggestions?. By the way, here is how she sits:
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-07-2008, 11:50 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Anybody use wheel spacers?
I'm running them on the rear with my rallies on my '69 C/10 and they really improve the look. They are 1.25" spacers that came from someone on Ebay. My rear tires are 275's so your's should be in just slightly. As far as quality I have ran these for years with no problems. Just make sure you get the 6061 T6 billet ones and not the cheaper cast aluminum ones. You should be able to get a set on Ebay for less that a C-note.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-07-2008, 11:52 PM   #3
dieselarmy13
That would be what I'm lookin for. Thank you,sir!
Old 06-07-2008, 11:55 PM   #4
67_C-30
67_C-30's Avatar
Great looking truck BTW! What drop are you running?
My trucks
Old 06-09-2008, 12:23 AM   #5
dieselarmy13
Thanks,as far a drop goes, I couldn't tell ya the actual amount, but I'm running 2.5 spindles up front with one coil cut off. In the rear, I have leafs, so I pulled one or two leafs, don't remember how many, and used a DJM flip kit. I plan on going just a tad lower, but I need to redo my exhaust before I drop it anymore. The PO has a real nice cobbled up system on there, and the glasspacks are under the framerails.
Old 06-09-2008, 08:08 AM   #6
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I running them on mine for about three years now and don't have any problems. There kinda a pain when you need to do break work but other that that neime problema
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-09-2008, 08:19 AM   #7
orange72c10
I put a set on front and back this year and think they really improve the look of my truck and do not have any problems with them at all!! I have 1.25 inch on the front to clear the studs and I have a 1" set on the back. I was only going to buy a set for the front because the 15" rims that i bought had clearance issues on my lower control arms but after i put them on the front I noticed that the wheel studs were to long so i tred them on the back and they worked and bought the right ones for the front, I think it looks a bunch better now that they are both pusehd out that extra inch!!
1964 volkswagon, dune buggy
1972 cehvy c 10 with 48000 miles original, bought brand new by my grandfather
1978 chevy elcamino
orange72c10 is offline   Reply With Quote
