06-07-2008, 11:25 PM | #1 |
Luv the Crewcabs
Why Does this Bed fit so Bad?
What would cause a Bed to Fit as Bad as this one Look's?
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
06-07-2008, 11:28 PM | #2 |
Re: Why Does this Bed fit so Bad?
Maybe it needs some new bed mounts? Or possibly used 3/4 Ton cab mounts?
EDIT: Looking at the picture again, it looks like the front of the bed is the problem. Notice how close the front of the rear tire is to the fender.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-07-2008 at 11:30 PM. |
06-07-2008, 11:32 PM | #3 |
the beds didnt have mounts IIRC...almost looks like they used the "short" cross seals on all the cross seals......or they have cab/rad mounts that are used for a body lift...
06-07-2008, 11:34 PM | #4 |
Official Site Guitar Shredder
agreed
06-07-2008, 11:34 PM | #5 |
Tot Roddin'
looks as though the cab has been lifted, with lift spacers, or 3/4 spacers.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-07-2008, 11:51 PM | #6 |
Luv the Crewcabs
06-08-2008, 05:17 PM | #7 |
needs work, but the cab and front fenders need the trim removed to look right with a bed with no trim on it. I'd have shimmed the bed upand elongated the mounting holes to get it closer to the cab lines, and took the trim off before paint.
06-08-2008, 06:40 PM | #8 |
All rubber mounts are not created equal. The guy that redid this truck used different mounts creating an uneven look. The prior owner of my C/10 redid my mounts and the truck actually looks better then normal, but the bumper sits lower and now I have to use spacers to raise it. The orange truck is nice though!!! Good post!!!!
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
06-08-2008, 06:47 PM | #9 |
something deff outa whack there, but gotta agree that the trim shoulda been taken off.after that should be a nice looking truck tho
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
06-08-2008, 07:06 PM | #10 |
huh ???
I looks like the rear of the cab is sitting too high. Like mentioned, somebody probably used 3/4 ton or 4x4 cab bushings on it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
06-08-2008, 07:18 PM | #11 |
its the cab thats mounted to high, in the side shot the top of the front wheel well is actually higher than the rear
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
