06-07-2008, 11:34 PM | #1 |
Tasty Cakes!
Antennas
Gotta replace my antenna eventually. Anyone using anything other than a factory one? What about filling the antenna hole and using one of the "in-the-windshield" ones? Custom billet? Boomerang? What ya got??
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
06-08-2008, 12:06 AM | #2 |
I have a radical idea!
Re: Antennas
Here's the imfamous Ultra-Rare Corvette Option (RPO#OU812) hood mounted antenna. They had to do this because the HI PERF ambulance engines that came with the Corvette option had so much torque that the antenna would break the windshield on hard launches.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
06-08-2008, 12:15 AM | #3 | |
Trucks N Tranzams
Re: Antennas
Especialy the hard launch bit.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
06-08-2008, 12:20 AM | #4 |
Re: Antennas
Its the only way I can deal with being the new owner of the famous hood antenna truck. I'm secretly crying on the inside!
06-08-2008, 09:58 AM | #5 |
Active Member
Re: Antennas
I have temporarily put a cheapo powered windshield one from O'reilly's. I think I paid around $20 or so for it. Works pretty good in town and the outskirts - at least in my area- but once you get out of town it's iffy.. Not bad for the price though.
btw: I mounted it on the center of the rear window just below the dome light. Then I routed the wiring inside the top of the cab (same dome light hole), down the rear passenger side, along the door bottom (channel) and up the right hand side kick panel area. ANTENNA'S - ANTENNA (AMPLIFD WINDW AM/FM) Item No: AWUA200 forgot to add: had to do some solder splicing for antenna cable length... Last edited by 68gmsee; 06-08-2008 at 09:59 AM. |
06-08-2008, 12:20 PM | #6 |
Barrito Loco Diablo
Re: Antennas
I have no exterior antenna. Wasn't really sure if the truck had one factory or not. Did they all? I'm using a window mount antenna that i have snaked under the floor rubber, behind the bench and stuck to the passenger side pillar next to the rear window. not noticeable, but i only get 1.5 stations. I use the tape adapter with the I-pod though. My dad used to have a early 70's Ram with a z'd antenna. Always reminded me of ZZ-Top.
06-08-2008, 12:23 PM | #7 |
PROJECT 7DEUCE
Re: Antennas
Dont ask me I just bought a repo one cause some little basturd stole the mast off my other one... Theief must have know how much money they cost..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-08-2008, 01:22 PM | #8 |
Barrito Loco Diablo
Re: Antennas
prolly just wanted a whip to beat people with, or the thing in the city is stealing them and smoking crack with em. That's what my neighbor said anyways....
06-08-2008, 02:43 PM | #9 |
20' Daredevil (Ret)
Re: Antennas
I got my stainless fixed-mast antenna (and a bunch of other stuff) in 1992 from Flow Chevrolet of Winston-Salem, NC. At that time they had a restoration center with parts for older GM vehicles, and some very helpful people. Dunno if they are still in that business, though the dealership is still there. 888-550-3569
Only p/n on my invoice says L21A Antenna GS.
06-08-2008, 05:17 PM | #10 |
Re: Antennas
Put this retractable in so I didn't have to put a hole in my cover. The hole was already in the fender not a stock location.
69 Chevy 4x4 383 Power |
06-08-2008, 09:33 PM | #11 |
Re: Antennas
You could always shave the gas hole & do what I did.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-08-2008, 09:38 PM | #12 |
Re: Antennas
I think if I'd do it again I woulda put in a shaved bed pocket.
