Old 11-07-2002, 09:57 PM   #1
1968GMC
love my truck
1968GMC's Avatar
427 cid ?
I mitgh be able to get my hans on a C50 truck with a 427 CID for $500, maybe less. Is that a good engine choice for a 1/2 ton? Will it bolt to a th350? Can you buy aftermarket parts like headers,intake ,carb, cam that sort of stuff?
1968GMC is offline   Reply With Quote
Old 11-07-2002, 10:03 PM   #2
mikep
Used to have a truck
mikep's Avatar
The 427 in that truck is an industrial/heavy truck engine. It is about the same as a big block chevy except for a taller deck, different rods and pistons which can be swapped to regular big block pistons with longer aftermarket rods. The distributor is different as s the intake. All the parts are avaialable but they are more expensive. Thick walls in the cylinders and they make for good race motors.
No truck :-(
mikep is offline   Reply With Quote
Old 11-07-2002, 10:48 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
and its a GM casting so it has same bellhousing pattern as all 55-up engines did
Fast68Chevy is offline   Reply With Quote
Old 11-07-2002, 11:37 PM   #4
adamls
Gotta Startem Early
adamls's Avatar
Mucho torque!!! You would have to rebuild if you want top end though. $$$. Should bolt right in, I would do it.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 11-07-2002, 11:47 PM   #5
1968GMC
love my truck
1968GMC's Avatar
I assume the TH350 bolts to it and/but will it whitstand the extra tork?
Old 11-07-2002, 11:53 PM   #6
adamls
Gotta Startem Early
adamls's Avatar
Only one way to find out, if it soesnt then you can have it rebuilt to withstand. One way or another it will have to be rebuilt, right?
Old 11-08-2002, 03:37 AM   #7
Hooter
My other Love
Hooter's Avatar
The bigger the better!. I wouldnt trust a turbo 350 behind it though
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
