Old 06-08-2008, 12:33 AM   #1
drewfever1020
hard to turn
my truck is hard to turn the wheel and i need help on were to lube it up to make it turn easy. my truck is a short step 69 and it dosnt have a place to put power steering liquid so i think it didnt come with it, so im guessing it needs to be lubed?
if u guys can help me on were to lube it, it would be cool!
pics would be good too!
thanks!
drewfever1020 is offline   Reply With Quote
Old 06-08-2008, 12:48 AM   #2
71swb4x4
71swb4x4's Avatar
Re: hard to turn
These things can be beasts with no power steering.
A couple optoins - the obvious one is to add power steering. Other options include a larger steering wheel or skinnier front tires.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-08-2008, 05:01 AM   #3
HoupPhotography
Re: hard to turn
I agree, I don't have power steering but I have a tractor steering wheel on my truck... Not really, it's the original steering wheel and it's HUGE.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 06-08-2008, 05:42 AM   #4
jimfulco
Re: hard to turn
It'll get easier as your upper body strength develops.
jimfulco is offline   Reply With Quote
Old 06-08-2008, 07:58 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: hard to turn
Sounds like you may have the optional "Armstrong" power steering.Or on a 40 year old truck someone may just have removed the PS pump and it would be a bear to turn.
You may help it a bit by crawling under over and around the front suspension with a grease gun,but don't expect miracles.Put 3-4 shots of grease in each zerk.Check your tire pressures also.
If you can take pics of the steering box we may be able to help more.There are lots of members who have updated to PS also.
Does the steering get easier when you are moving?
Give a few more details on what you are dealing with.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-08-2008, 09:33 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Re: hard to turn
After you've done and checked all what was mentioned above and it's still stiff, you may need to lube the steering shaft in the column. Grease gets hard and makes it harder to steer and shift if you have 3 speed column like mine did.
This is not easy if you're not mechanically inclined or familiar with steering columns. Some guys have just sprayed WD40 down the tube and worked it back and forth.
In my case it didn't help very much when I spray lubed the shaft on mine loooong time ago. I actually had to remove my column from the truck and literally remove the tube and shaft, clean it and regrease it. You man not have to get this drastic.
68gmsee is offline   Reply With Quote
Old 06-08-2008, 09:43 AM   #7
caminokid
Chevy nut
caminokid's Avatar
Re: hard to turn
My 69 fleet was a bear to drive for my girlfriend...but I drove it like it had power steering. Until it was stopped then I fought the steering to back it up or parallel park. Thats one thing I dont miss about the old girl. I know it needed the front end rebuilt.
If you rebuild your front end it may make it easier.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-08-2008, 01:54 PM   #8
Green Machine
Green Machine's Avatar
Re: hard to turn
Adding power steering is likey your best bet. Most of the old manual steering boxes have leaked all of the lube out by now. A new/rebuilt manual box really does not turn all that hard. Problem is most of the manual boxes are half worn out, have have the adjusting screw tightened to take out the slack and then they bind up and turn hard.
We have a 1970 with 265/70/17 tires on front and the manual box and it turns pretty good, box is a llitle loose though. Not going to put any money into the manual box, going to power steering and a smaller steering wheel when the time comes.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-08-2008, 06:57 PM   #9
drewfever1020
Re: hard to turn
alright cool!
i will try the to lube everything on there and ill let u knw if it worked!
thanks!
