Old 06-08-2008, 04:53 AM   #1
knightlife
Dark Heart Motorsports
knightlife's Avatar
major question with rear ends...
aight, I know Im not on here as much as I used to be... been overly busy working two jobs.
but here goes,.,.,.,
I was curious as to what car/truck rear end assembly (meaning axles and all, the whole shi-bang), I could swap to to keep my 5 lug setup, and get posi.
hopin to do a straight swap if possible.,.,.
thanks in advance!
Kru
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 06-08-2008, 05:18 AM   #2
jimfulco
Re: major question with rear ends...
Assuming yours is a half-ton 2WD w/10-bolt rear end, a rear end from any similarly configured pickup up through '87 or Suburban up through '91 should be a bolt-in. A 12-bolt dating back to '73 would also fit, but the driveshaft for a 12-bolt needs to be a bit longer than one for a 10-bolt.
Try to avoid one with the Gov-Lock "posi" carrier, because they don't hold up well to hard use.
Might dig around at www.car-part.com and see if you can find one in your area.
jimfulco is offline   Reply With Quote
Old 06-09-2008, 11:42 PM   #3
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
My 79 heavy half or big 10 has a stock 12 bolt with 5 on 5 studs.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
