11-07-2002, 10:14 PM | #1 |
No dash lights
I went from a non gauge dash to a gauge dash and now have no dash lights...I followed the instructions from GMC Pauls website on swapping wires on the wiring harness...and the dash gauge wire has power to it in the harness...I do have turn signals and the temp light comes on when you turn the key on to start...but no dash lights...could a non functioning reostat on the light switch be the problem ??? Or where else should I look ???
94 K1500 SWB w/ 4" body and suspension lift |
11-07-2002, 11:11 PM | #2 |
i thought mine was the rheostat spring for a long time but actually there was a blown bulb...there in circuit so they all go out with one...check that...its easy enough...-Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
11-07-2002, 11:23 PM | #3 |
guess that information would have been helpful in my original post..I replaced all the bulbs w/ new 1's.
11-07-2002, 11:33 PM | #4 |
got a ground?????
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
11-08-2002, 01:27 AM | #5 |
its all about the +6 inches
Interesting, your lights should not be in series...I have one missing on the fuel guage on mine...but all the others work fine.
If the fuel guage and turn signals are all working, then the inst panel is properly grounded. A head light switch could be the problem. However, first I would look at yoru printed circuit board on the back of the inst panel. Look where the plug goes into it, see if there is a 'wire' (on the board...not the harness side) that is not plugged in properly. This would be my first suspision. |
11-08-2002, 11:19 AM | #6 |
Are your tail lights working ? could be just a fuse.
'68 Fleet LWB orig 307 .030 over GM Hei/w Accel Super coil orig. stock TH 400. _______________________ “What we do for ourselves dies with us. What we do for others and the world remains and is immortal.” Albert Pine English author d.1851 |
