06-08-2008, 11:53 AM | #1 |
tire and wheel ???'s need pics of wide tires
I can't decide on what tire wheel combo. I want 10-12" of tread on back and not sure on front, but I want the back to be 28-29" tall.
15's or 18's, no 20's. It seems like when the tires get wider they get shorter. Ya'll show me some pics and put the sizes on there so I can decide. Thanks |
06-08-2008, 01:00 PM | #2 | |
Re: tire and wheel ???'s need pics of wide tires
I've been looking for the right combo for 17s. 275/50s look great on the rear, and are about 28" tall, but I can't find a matching 28" tall tire for the front that is not quite so wide. 255/50s are a little short for me. 275/55s and 235/65s are close, but about 29" tall. Here's a good tire size calculator to play with. http://www.1010tires.com/TireSizeCalculator.asp I've found that if you do a search here for the size tires that you're interested in, like 275/50/17 for instance, you will get some good pics.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 06-08-2008 at 01:02 PM. |
06-08-2008, 08:07 PM | #3 |
67-72 Addict!
29x18.5x15 Hoosiers on the rear of this truck I snagged off the net
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
06-08-2008, 08:54 PM | #4 |
06-08-2008, 09:26 PM | #5 |
its all about the +6 inches
275/60 R 15s are 10 inches(ish) wide and 28 inches (ish) tall... depends on who makes the tire. I've seen one marked that sixe be almost 12 inches wide. You'd think with the 275 part of that equation being a simple measurement (275mm) they'd be able to get it right.
06-08-2008, 09:36 PM | #6 |
Chevy nut
Here is my 69 stepper. 30X10.50 15's
Using later model 4X4 Rims
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
06-08-2008, 10:14 PM | #7 |
I am on the road so I can't show you pics. But I have P295/60/15 Firestone Indy 500s. They are the right height you ask about and when mounted to a ten inch rim (Weld Pro Stars) they squat to 13 inches wide.
Kerry
1967 C10 Got it back after three years Boy I sure missed Peppy 1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
06-08-2008, 10:23 PM | #8 |
i have 29-12.50-15's on 12 inch welds with 7.5 back space i think a 15.5 would also fit but didnt wanna rub them so i went with the 12.50's
06-08-2008, 10:49 PM | #9 |
Rolled on Paint Club
275/60/15's on the front and rear on 8" steel wheels. The front one shouldnt stick out quite that far, frame is bent a little.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
06-08-2008, 11:50 PM | #10 |
72 Chevelle Club
275/60/15 BFG on 15x11 steel rally's
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
06-08-2008, 11:52 PM | #11 |
06-08-2008, 11:56 PM | #12 | |
06-09-2008, 01:19 AM | #13 |
Here is my truck.
Rims are 17 x 8 and 17 x 10 with 4.5BS. Tires on the rear are 285-60-17 and the fronts are 275-50-17 (think that is what the fronts are anyway). There are a few more photos in my build thread below.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
06-09-2008, 01:40 AM | #14 |
The Engine Whisperer
06-09-2008, 06:22 AM | #15 |
06-10-2008, 07:39 AM | #16 |
31 X 16.50 - 15
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
06-10-2008, 01:38 PM | #17 |
I have mickey thompson Sportsmen tires on mine not the new SR's tho just the reg. ones mounted on 15X 12 weld drag lites
06-10-2008, 02:23 PM | #18 |
Here's one that's kinda fun to play with...
http://www.wheelsmaster.com/rt_specs.jsp and another... http://webrodder.com/calculators/Hub-Wheel-Tire.xls Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 06-10-2008 at 02:36 PM. |
06-10-2008, 06:04 PM | #19 |
I like this tire calculator as it has backspacing and plus 1 & 2 sizes for taller rims (though some sized are theoretical).
http://www.rims-n-tires.com/rt_specs.jsp |
