06-08-2008, 01:08 PM | #1 |
6" lift, e-brake cables???
I'm in the process of installing a superlift all spring lift in my blazer. I've got the back springs done, but now the e-brake cables are too short. What is a good replacement for them. I was thinking of trying ones off a truck as they would be a little bit longer. Oh yeah it still has drum brakes in the back.
06-08-2008, 01:32 PM | #2 |
PROJECT 7DEUCE
Re: 6" lift, e-brake cables???
MMMM I dont remember haveing this problem??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-09-2008, 11:59 AM | #3 |
Project Junkie! Fishing Poor!!
You could always have custom cables made by in-line tube. You would have to know the length that they need to be though. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-09-2008, 02:50 PM | #4 |
Future TOTM Winner
I have the same issue. Wasn't sure what the correct fix was.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
06-09-2008, 05:31 PM | #5 |
Could anyone with a shortbox or longbox truck tell me the length of their cables? I think it would be cheaper to get a set for a truck than have some made up.
06-13-2008, 08:55 PM | #6 |
you can get some good cheap cable for what you are looking for at any bike store. shift cables for bikes or brake cables will work, they have the little locking thingies (i dont know what they are called) its what hooks in at the brake/brake lever and the shifter and shift pod. they are also very durable and if you spend a bit more money on them you can get ones that have a coating so they wont rust
06-15-2008, 12:31 AM | #7 |
Hey, finally a question I know the answer to! The answer is ... a G30 van. Yep, I had too much lift when I bought my 72 and the e-brake cables were not connected. Not a big deal, I thought, until I found out that the e-brake is part of what adjusts the rear brake pads so that they stay the right distance from the drum. So what I found out over on the ColoradoK5 message board was that the cables (and the little metal parts that bolt onto the back of the brake) are the same but longer on the vans of about the same year (maybe until 1976?) and maybe on some of the trucks with longer wheelbases, but I got mine of of a van, so I can vouch for that. Here, I think I have photos. Oh, I also moved the bracket that mounts on the frame to the bottom but it turned out with the longer cable that I didnt need to do that after all.
06-15-2008, 12:34 AM | #8 |
Ok, it wont let me post the photo because it is 165 KB. Anyone know how to change that?
