drive it till it dies
fuel filter??
fuel filter before or after fuel pump????
fugedaboutit
![]() Join Date: Mar 2005
Re: fuel filter??
After. Just dont run a glass one. In the engine compartment is easier to work on also.
Currently truckless ![]() Last edited by redhead69; 06-08-2008 at 01:32 PM. |
Junior Member
Re: fuel filter??
There seem to be differing opinions on this from time to time, some say before and some say after.
I run mine after the fuel pump because I have heard running it before the fuel pump can cause vapor lock. No matter what a metal fuel filter is the best, they tend to hold up better and don't break or melt. Danny |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: fuel filter??
its all about the +6 inches
Re: fuel filter??
after the pump.
Re: fuel filter??
Both. I like to run an inline filter between the tank & pump. Then have a filter in the carb inlet. If you have a brand new tank it's not necessary for one from the tank to the pump.
#7 | |
20' Daredevil (Ret)
Re: fuel filter??
Moderator
![]() Join Date: May 2007
Re: fuel filter??
Between Trucks...
Re: fuel filter??
Beat it to fit, Paint it to match... ![]() |
Re: fuel filter??
before the pump if you are running an electric... after if mechanical.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
Re: fuel filter??
you can pump sand through a mechanical pump and it won't phase it
Re: fuel filter??
Whats the reasoning behind putting a filter before a electric pump? If you are driving a chevy newer model which has a in tank unit fuel pump it's filter is after the pump.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#13 | |
Re: fuel filter??
http://static.summitracing.com/globa...199r7914-2.pdf scroll down to page 2. They actually recommend you run a T fitting with TWO filters before the pump - that just seems like plain overkill. But, a 5 dollar pepboy steel filter is some cheap insurance and keeps its unsightly arse out of my engine bay.
#14 |
Re: fuel filter??
I wonder if thats just a way to say warranty void in case their pump fails? Extra insurance sorta deal. I read that Thanks. I wouldn't put a dual filter setup unless I was running a drag car or the indy 500 or an airplane. One filter should be plenty on most applications.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 06-09-2008 at 12:36 AM. Reason: revised |
#15 |
Re: fuel filter??
Edelbrock also says my warranty is voided if I don't have a filter before the pump on my TBI system
69 Chevy 4x4 383 Power ![]() |
#16 |
Re: fuel filter??
Don't most EFI systems still use a "sock" or strainer of some type before the pump? I think as long as the pre-pump filter has little to no restriction, it won't tend to cause vapor-locking or cavitation.
#17 | |
Re: fuel filter??
Maybe I'm reading it different than is intended though. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
#18 |
Re: fuel filter??
they have sock type screen filter that fuel has to go thru before entering the actual pump
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
