06-09-2008, 01:35 AM | #1 |
Always wrenching!!
Ls1 rear disc.....
So i used a set of ls1 camaro rear disc on my 72 camaro, worked perfect bolted right up. well i was under the impression that 10 and 12 bolts had the same axle flange. So i came across a 2nd set of the LS1 brakes. well come to find out c-10 had a different 12 bolt flange..... CRAP haha.
so the question is, does or has anyone used ls1 calipers.... what mounting bracket did you use? what rotors?
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
