06-09-2008, 12:15 PM | #1 |
Window Felt Install, pics needed
Last night I installed the window felt strips on my doors along with the wing windows on my '69. When I look at the result, it seems something might be wrong. The inner felt strip at the bottom of the opening extends all the way back into the upper/back chanel, overlapping the felt that goes on the top and back side of the opening. Also my wing windows have a gap on the outside of the door. I tucked the rubber into the door (?)
Does anyone have pictures of the felt strips and wings installed properly? I would love to get shots of the inner and outer strips showing both the ends and some of the wings as well... Thanks |
06-09-2008, 01:56 PM | #2 |
Saving 1 truck at a time!
Re: Window Felt Install, pics needed
If you are referring to the anti-rattle felt and rubber strip, I recall having to trim mine to fit. I believe they are made long.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-09-2008, 03:19 PM | #3 |
Restoration Virgin!
Not sure if this will help any....but this is a thread I started awhile back...
http://67-72chevytrucks.com/vboard/s...d.php?t=287765 hope this helps!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
06-09-2008, 11:26 PM | #4 |
thanks... the wings seem to be right so now I will cut down the felt strips to fit better. Still could use a pic of wear the outside felt strip meets the wing...
Thanks again |
