Old 06-09-2008, 12:26 PM   #1
19gmc67
19gmc67's Avatar
Unhappy my truck isnt starting pics added
i just started work on my 67 gmc got it running.started working on it a few days later it wont do anything.checked the battery it was good,checked the alt. it was good,and checked the starter it was good.what am i doing wrong ...................need help!!!!!!!!!!!!!!!here the pics of the wiring i think its shot what do yall think.
19gmc67 is offline   Reply With Quote
Old 06-09-2008, 02:19 PM   #2
Luvlegs
Luvlegs's Avatar
Re: my truck isnt starting
Do you have power to the switch? How about the rest of the circuit? Are the fusible links (near the batterY) still good? Probably need to do a little more trouble shooting and then help might come easier. Good luck!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 06-09-2008, 02:32 PM   #3
19gmc67
19gmc67's Avatar
no power to switch
Old 06-09-2008, 03:10 PM   #4
dls69cst
Check the neutral safety switch under dash. I had this problem before.
Good Luck,
Later...
1969 cst swb
dls69cst is offline   Reply With Quote
Old 06-09-2008, 03:11 PM   #5
jhow66
jhow66's Avatar
Fuseable link is blown at junction block near battery. (check red wire at alt. for power)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-09-2008, 03:16 PM   #6
19gmc67
19gmc67's Avatar
Good Luck,
Later...
where is this located
Old 06-09-2008, 03:27 PM   #7
jhow66
jhow66's Avatar
There will be a heavy red wire coming off battery + post(not battery cable) that goest to a small junction block on the fender bracket. The black wire off this block is the fuseable link. (check after this link for power-if no power replace link.)
Old 06-09-2008, 03:30 PM   #8
jhow66
jhow66's Avatar
On steering column under dash-purple wire in and out (if you have an automatic trans).
Old 06-09-2008, 03:33 PM   #9
El Jay
Gone to greener pastures
Does anything else have power; lights, radio, etc?
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-09-2008, 03:36 PM   #10
19gmc67
19gmc67's Avatar
have no power at all,truck doesnt have the orignal motor,but has the orignal wiring.look under project forum [projectnightmare]to see what im working on
Old 06-09-2008, 04:35 PM   #11
El Jay
While you're chasing down the hot side of everything, also check the battery ground.
Make sure that both ends of both cables are clean, bright, and tight
This is just an illustration of how strange some of these electrical problems can be:
I had a problem on my Plymouth a couple years back that was bizarre, to say the least.
Like you, I no power to anything.
I spent over a week trying to chase down the problem with a VOM and a looooooooooooooooong jumper attached to the negative battery cable terminal.
I started at the positive battery terminal, then then the cable end.
I followed it step by step, through the fusible link to the solenoid. I also followed the battery cable to the solenoid. Everything was fine. I dug out the wiring diagram and chased the power to the bulkhead, then inside to the fuse block. Everything was good.
For whatever reason, I moved my jumper to the engine block. There, I nothing.
I wiggled the ground cable near the block terminal and power would come and go. It was breaking down between the cable and the terminal.
I replaced the ground cable and things were fine.
Sorry I ran so long, but this is just how elusive some of this electrical crap can be.
Old 06-09-2008, 07:41 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I had a Chrysler New Yorker years ago.It would start fine maybe for several weeks,then suddenly nothing.Sometimes a jump would start it sometimes not.I could not find a short anywhere.Battery cables were cleaned repeatedly.Installed new cable ends.It might not start for a month then just fire up perfectly when tried.
One day when trying to start it my buddy gave me a jump and nothing.He reached over and put the positive cable on the starter and it cranked right up.Turns out the copper in the cable had corroded completely in half inside the insulation.I replaced the cable and drove it for 2 more years without a problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-09-2008, 11:25 PM   #13
19gmc67
19gmc67's Avatar
thanks for all the tips
Old 06-09-2008, 11:40 PM   #14
Dr.Jones
Dr.Jones's Avatar
I just had a no start problem. ignition module. Always check for spark.
70 K-10
75 CJ-5
90 XJ
Smell the Magic!
Dr.Jones is offline   Reply With Quote
Old 06-11-2008, 12:55 AM   #15
19gmc67
19gmc67's Avatar
pics added
Old 06-11-2008, 11:21 AM   #16
Luvlegs
Luvlegs's Avatar
Check the FAQ section - there are diagrams you can use to trace out the wires that are missing/unhooked/broken.... Perhaps someone can post a link if you can't find it.
While you are in there, I'd wrap that skinned pink wire in the second pic - that's just an arc away from a major headache.
1972 C10 L6 3OTT
Old 06-14-2008, 10:03 AM   #17
Kayotic
Kayotic's Avatar
If the truck is totaly dead electricaly - Check the block mentioned on the pass. fender. I just did this yesterday.
Kayotic is offline   Reply With Quote
