Old 06-10-2008, 02:21 PM   #1
ron19
Made some progress
Made some progress on my 65' project. Thought I'd share some pics.
The first is after the firewall and fender paint job, installed the brake booster and new master cylinder from cpp, fresh painted blower/heater box.
Second is a close up of the master cylinder/booster install. I got a booster from a mid 80's grand prix, the donor truck booster was too big for my clutch pedal master. The master cylinder is cast iron, for a change in the black color scheme I painted it clear to keep from rusting, but it looks like a glazed donut now (not in this picture)....lol.
Next is the power steering upgrade. Steering box from donor (75') truck and bracket kit from cpp. Worked great, cept they sent me an incorrect (fine thread) bolt that threw me off for a good 1/2 hour.
Next is the front cross member or "saddle" as I like to call it. Painted, and now installed. Looks so much better.
And last is my disc brake spindles from the donor truck, cleaned and painted. Note the tie rod assembly, I do a lot of dirt track racing, and we use inner tie rods with the swaged adjuster tubes and heims on the outside. The spindle is drilled to a through bolt and the heims connect to the spindles. Looks cool I think!
65' Chevy C10, Short Step
75' Chevy Big10 1/2, 1 time pull truck, now parts truck
02' GMC 2500HD 8.1L 4X4
ron19 is offline   Reply With Quote
Old 06-10-2008, 02:38 PM   #2
joe231
joe231's Avatar
Re: Made some progress
looking good.
that tie rod idea kinda scares me though, maybe I'm a puss
CHEVY ONLY
Old 06-10-2008, 02:50 PM   #3
83burban
Does that HEIM joint make the steering loose at all? Never seen anything like that before.
83burban is offline   Reply With Quote
Old 06-10-2008, 03:15 PM   #4
ron19
We use the tie rod tubes and heims on dirt modifieds, running anywhere from 90 to 140 mph all while banging doors with other cars. So the technology has definately been tested.....lol.
I use this on my race car, and the steering just feels smoother. Definately not loose (unless the heim is worn out and there is slop in it), just nice and smooth.
Old 06-10-2008, 05:35 PM   #5
scotts62
One day...
scotts62's Avatar
Ya that heim joint thing you have there is pretty cool, ya 90 to 140 would be fun to test out
Scott
93 crew cab build
Project 62
Old 06-10-2008, 09:47 PM   #6
Lane
Looks great! I had the same problem with my PS CPP kit - and a fine thread bolt..
Lane is offline   Reply With Quote
Old 08-18-2008, 09:41 PM   #7
ron19
Progress is slow, but I've got a little done. Figured I'd show everyone how the steering components look together.
Old 08-18-2008, 09:51 PM   #8
joe231
joe231's Avatar
nice
CHEVY ONLY
Old 08-18-2008, 10:32 PM   #9
MacAttack
283 Drama Queen
MacAttack's Avatar
Gutty work - great photos of some really nice labor.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-18-2008, 10:50 PM   #10
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Your doing a great job, keep it up.
I'm glad I read your thread about the fine thread bolt. I'm at the point of drilling and mounting. I noticed the fine thread bolt in the CPP kit and wondered about it. Thanks for the heads up.
Alan's Classic is offline   Reply With Quote
Old 08-18-2008, 11:05 PM   #11
TimE
Hey Y'all!!
TimE's Avatar
That's a nice looking setup. Good job!
TimE is offline   Reply With Quote
Old 12-04-2008, 01:46 PM   #12
ron19
Not alot of progress but some. Hoping to get some wiring for Christmas so I can install this mill and fire it up. I finished running the brake lines for the updated disk brakes.
Old 12-04-2008, 01:53 PM   #13
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Good looking build. Is that power plant a 383? Im digging that mill you got there! Nice!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 12-04-2008, 02:21 PM   #14
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Nice looking engine.
westbrookw is offline   Reply With Quote
Old 12-04-2008, 02:23 PM   #15
c10addict
c10addict's Avatar
Nice work... Can't wait to see it done..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 12-04-2008, 02:44 PM   #16
4dranch
Shloooooong bed member #2
4dranch's Avatar
sweet......
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 12-04-2008, 05:14 PM   #17
ron19
Thanks for the compliments, that keeps me working on it when I can.
The mill is a 406 (400 .030 over) I got a set of AFR 190cc heads, eagle crank, scat rods, solid lift oval track cam (had it laying around), shaft rockers (had those laying around too), Edel RPM airgap, holley 830hp carb, etc. Should put out about 500 ponies when done. I have a lot of parts from circle track racing left over, so figured I'd use them up. You can see my stock car influence in the steering componants as well as the engine. If the stuff works in that rugged of conditions, it should work good on this. My thoughts anyway.
Old 12-04-2008, 05:25 PM   #18
283 Man
283 Man's Avatar
Thumbs up Re: Made some progress
sweet!! that puppy should sound good after you fire it up
283 Man is offline   Reply With Quote
Old 12-04-2008, 05:30 PM   #19
jchav62
1962 C-10
jchav62's Avatar
Nice!!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
