Packrat
1972 Door panel sealer?
searching through the posts, and most threads are about swapping door panels out, and some about cloth covering for door panels....
has anybody tried a sealer or something for the 1972 panels? mine look okay, but the top layer has gone soft, and if I hit it with a fingernail or hard object, it gouges a little, and removes some of the plastic... for the time being, I'd like a way to seal it up if possible to stop the degradation. (if it's not too far down that path already...) thoughts?
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
Re: 1972 Door panel sealer?
I washed mine down good with laquer thinner and a real stiff plastic brush - they were getting "pebbley" - then I used a kylon plastic paint that just so happened to match my parchment interior perfectly. I'd rate them as 3 footers.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
its all about the +6 inches
Watching thread closely, as i need to do the same on mine.
Luvlegs... how long ago did you do this, and do you have the paint #? |
![]() Join Date: Dec 2002
I would give the panel a coat of expoxy resin....( available at boat suply dealers and most of the larger hardware stores).. and probably the less expensive polyester resin would work very well also... Hardener is required with both products
The resin will ad stiffness to the panel and will be an excellent sealer for top coat of fabric, paint or whatever your desire...Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). Last edited by GMC Jim; 06-11-2008 at 07:19 AM. |
I did it about a month ago - I'll post some pics so you can see what it looks like using paint. Not to jump over the thread but just to show one alternative.
I wanted to match the door panels and handles to the belts, visors and headliner - I used Krylon "antique white" - it was the same yellowish color of all my parchment stuff. (I'll confirm the krylon brand tonight) First pic shows all the parts and the difference between door panels and the rest of the parchment stuff. The second pic, the color to match. A good cleaning, wipe down with laquer thinner and light even coats makes them nice. I make all attempts to not get in with greasy hands or dirty clothes so as to not prematurely wear out the paint. If I do, I'm out 6 bucks for paint and the time.
I think I need to get some paint.
Thanks for the tip, and let me know what the paint number is. I'm droolin over those photos. i was thinking clear, but wasn't too thrilled about that idea. |
I am a Referee of life.
I would almost bet that it is Krylon Plastic Fusion.I haven't used it but have heard several people swear by it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Parchment panels are the worst at oxidizing and getting soft. Mine below were the same. The guy who restored them lightly beadblast them to remove the loose stuff then paints them. . You loose some of the grain in the plastic but not too much if they are'nt too bad bad to start with. It is still better to remove the loose plastic than to just paint over it.
72 Cheyenne Super 80 Silverado Blazer 2wd |
well, keeping with the $6 I mentioned - turns out I was wrong about the paint it's actually plasti-kote - T-27 Antique White. The part number is on a bar code sticker on the can with the name - the number is 0 71915 00127 7. (I'd imagine the first 0 and last 7 get dropped) It's definately not show truck type stuff but it looks good to me.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 06-11-2008 at 08:50 PM. |
awesome!
I'm thinking of doing the dash pad next - it's similiar to the arm rests and they came out pretty cool. I know I should do black and do my column black but as everyone says, "It's mine so I'm doin' what I want to do"
