Old 06-10-2008, 05:37 PM   #1
MisterE72
Keep Your Nose Clean
How do I fix this?
I was test fitting the front shocks and noticed that the hole on the frame is all messed up. Does anyone have any ideas on how to fix this? Preferrably without messing up the powdercaot finish. Thanks for any help you folks can provide. MisterE
MisterE72 is offline   Reply With Quote
Old 06-10-2008, 05:49 PM   #2
SactoJim
SactoJim's Avatar
Re: How do I fix this?
Mine was the same and I just welded it. Not much you can do without messing up the powdercoating except when you put the shock mount back on, tighten the ever loving crap out of it.......I would think it will be fine.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 06-10-2008, 06:19 PM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Mine was the same way. I had to weld it up...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 06-10-2008, 08:34 PM   #4
bigsnookmaster
bigsnookmaster's Avatar
Weld it. I've found Rustoleum Industrial Enamel in a can at Home Depot matches powder coating real nice.Some of my parts are powdercoated and some are painted,you can't really tell the difference.
bigsnookmaster is offline   Reply With Quote
Old 06-10-2008, 08:51 PM   #5
bucky_21_7
bucky_21_7's Avatar
u can always weld a washer to one side thats wat i did
bucky_21_7 is offline   Reply With Quote
Old 06-10-2008, 09:40 PM   #6
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
I'd either weld a stout steel washer to the both sides and touchup the P-Coat with some "Chassis Black" in a rattle can. Or I'd get two big ole honkin' S.S. Fender washers and use them on both sides of the stud and torque the livin' bejezzus out of them nuts (maybe even use Nylocks for additional insurance).
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 06-10-2008, 10:05 PM   #7
Infanti
www.infantimachine.com
Infanti's Avatar
If you have a machinist friend maybe he could make a custom bolt for you.Just a thought.
Infanti is offline   Reply With Quote
Old 06-13-2008, 07:50 PM   #8
MisterE72
I did a little research and founf this front upper shock mount rienforcement lit from CPP. The folks from CPP said to really tighten the the stud to the frame and bolt on this rienforcement kit. I hope it works. Are any of you all running one of these kits? How well does it work? Thanks for the help. MisterE
