Old 06-10-2008, 05:38 PM   #1
IAFF2407
IAFF2407's Avatar
need carb rebuilt
does anyone in the club specialize in rebuilding carbs (or know of someone), I need a 800 quadrajet rebuilt. I'd rather pay someone here.
thx,
Al.
#400 post
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 06-10-2008, 07:30 PM   #2
Ace in the hole
Re: need carb rebuilt
don't know if there is anyone here, but I have heard good things about http://www.cliffshighperformance.com/services.html
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 06-10-2008, 07:39 PM   #3
gn4u2c2
its truely a gravy job, just get a clean bench 1 gallon of carb clean at any auto parts store, your 1/4 inch set, a pic set, flathead #2 and a plastic pry set. you can order the kit at napa and go at it be sure to set your bases back to factory spec you can get the carb rebuild books at napa also. it will take about 1 hour
gn4u2c2 is offline   Reply With Quote
Old 06-10-2008, 09:34 PM   #4
Husker
Husker's Avatar
Cliffs is where I sent mine, have not gotten it back yet. They are suppose to be one of the best. They completly go through it and fix everything and use new parts and are also going to add bushings to the shafts. Should be getting it anytime. Alittle pricy but no worse than a ew carb.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 06-10-2008, 10:16 PM   #5
IAFF2407
IAFF2407's Avatar
that's what I need, re-bushed, new jets, and recalibrated etc.,. It came off a '77 425 and is going on the '71 500. I have the book, I figure by the time I buy new glasses (in which to see all the small pieces) the jewelry screwdriver set and a right thumb (hard to work with two left thumbs) it'll be cheaper and better from someone else.
1972 GMC Sierra
