06-10-2008, 11:27 PM | #1 |
KOFFIN DRAGGER
6 lug rotors?
I want to keep the burban on 6 luggars when I lower it, anyone know what 6 lug rotors came on or where to find some? I am going to use 2.5 drop spindles and 3" drop coils. also looking for a brake booster if anyone knows where to find one that fits our trucks. I cant afford the aftermarket kit, $900 for brakes is to much for a truck that already stops good.
06-10-2008, 11:40 PM | #2 |
Re: 6 lug rotors?
Classic Parts, CPP.
06-10-2008, 11:43 PM | #3 |
Re: 6 lug rotors?
Are you looking for a factory power brake booster and mounting wedge? If so, post an ad in the parts for sale forum.
06-11-2008, 10:03 AM | #4 |
Re: 6 lug rotors?
Here: http://www.truckandcarshop.com/trucks60_72/t60_115.html $75 each..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-15-2008, 01:57 AM | #5 |
Re: 6 lug rotors?
KD,
Check out D&R classics it's the palce that I bought my drilled and slotted rotors. They are not your mainstream truck parts place. However I know that they had 6 lug and 5.5 lug when I bought mine. I have to say DAM they are nice and not cheap repo's. I paid 168 for mine drilled and 5x5.5 but might be worth a look... Regards.. Heres a pic, I know that this is 5.5 but give you and idea how nice they are.... |
06-15-2008, 06:09 PM | #6 |
Re: 6 lug rotors?
soba,
$168 each??
CHEVY ONLY |
06-15-2008, 07:10 PM | #7 |
Re: 6 lug rotors?
1990 heavy half 6 lug rotors
Delco # 18A955 Mick |
06-15-2008, 09:03 PM | #8 |
Re: 6 lug rotors?
I have heard they don't work with the older spindles, offset is wrong
CHEVY ONLY |
06-15-2008, 09:10 PM | #9 |
Re: 6 lug rotors?
No that was for the set.... May seem a little high to some but I thought it was a good price for what I got...
06-15-2008, 09:22 PM | #10 |
Re: 6 lug rotors?
Yes, you do need the 88-9? spindles and 3/4 lower ball joints and 88 upper ball joints.
The 88-9? spindles are a dime a dozen and good priced too. Aftermarket lift or lowered. The rotors are cheap and the calipers are about the same price. At least I don't feel like I'm being abused for owning a 67 truck, by buying the later model common parts. I'm collecting the parts to convert mine right now (that's why I have the rotor part numbers in front of me) Mick |
06-15-2008, 09:45 PM | #11 |
Re: 6 lug rotors?
the light 3/4 ton rotors i have looked at are $80-$90 range, not what i would call cheap, but maybe that's because i am
CHEVY ONLY Last edited by joe231; 06-15-2008 at 09:46 PM. |
06-15-2008, 09:47 PM | #12 | |
Re: 6 lug rotors?
is this the place? http://www.drclassic.com/index.html all i see is Camaro and Chevelle stuff? oh and by the way....why 5 on 5.5?
CHEVY ONLY Last edited by joe231; 06-15-2008 at 09:55 PM. |
06-15-2008, 10:58 PM | #13 |
KOFFIN DRAGGER
Re: 6 lug rotors?
I found a pair a cpp for a $125, I think I will go that way.
06-16-2008, 03:04 AM | #14 |
Re: 6 lug rotors?
Joe,
That is the place, just call them Trust me the specialize in 55,6,7 chevy and camaro's and nova's But they have truck stuff too...Not like our vendors of course but they beat all the prices I could find for drilled and slotted. Yes 5 x 5.5 these are truck rotors..... |
06-16-2008, 08:19 AM | #15 |
Re: 6 lug rotors?
thanks Soba
I'm confused why you are running 5 on 5.5, Chevy truck pattern is 5 on 5, or 6 on 5.5. Dodge, Ford, Jeep, and IH are the ones I know of who have 5 on 5.5
CHEVY ONLY |
06-16-2008, 10:26 AM | #16 |
Re: 6 lug rotors?
If you use a mid 70's frontend set up and convert to 5 lug, you can get rotors for these prices.. http://www.partsamerica.com/ProductL...pe=221&PTSet=A
06-16-2008, 11:26 AM | #17 |
Re: 6 lug rotors?
Your right i'm a dumb A$$ these are 5 on 5 the 6 lug i removed are 6x5.5. This is the truck pattern 5x5.
06-17-2008, 12:15 AM | #18 |
Re: 6 lug rotors?
gotcha, thanks
CHEVY ONLY |
06-17-2008, 08:23 AM | #19 | |
Hollister, CA.
Re: 6 lug rotors?
So your say a 3/4 ton 88-98 ball joint will press into our old a-arms ? And is needed for the 1/2 ton lift/lower spindle ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 06-17-2008 at 08:24 AM. |
06-17-2008, 11:11 AM | #20 | |
Re: 6 lug rotors?
If the lower mounting cup is different then yes you would need 3/4 lower arms (I saw a bunch at the U-Pull It yard a couple of weeks ago) The upper arms, the ball joint just bolts in, no problem there Mick |
06-17-2008, 11:00 PM | #21 |
KOFFIN DRAGGER
Re: 6 lug rotors?
I have decided on the CPP rotors, mainly because a fellow board member, suicide_63, hooked me up with a swingin deal! I love this board!
06-22-2008, 03:36 AM | #22 | |
60-66 Nut
Re: 6 lug rotors?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-22-2008 at 03:37 AM. |
07-02-2008, 11:19 PM | #23 | |
Re: 6 lug rotors?
CHEVY ONLY |
07-03-2008, 12:01 AM | #24 |
Re: 6 lug rotors?
I am going to guess and say 70's spindles.. I would call the truck and car shop and ask them. CCP if they are cheaper...
07-03-2008, 12:22 AM | #25 |
Re: 6 lug rotors?
thanks
CHEVY ONLY |
