Old 06-11-2008, 08:45 AM   #1
lts70
1970 Daily Driver
lts70's Avatar
Hood Help
My hood has a bad heat warp so I found another hood in better shape. My question for you guys is, What grit of sand paper is best to use to take it down to bare metal? Also, I want to take the bottom of the hood down to metal but it has the factory undercoating still on it, is there a method or product that helps cut through this stuff? Thanks for the help.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 06-11-2008, 09:32 AM   #2
68_chop_top
68_chop_top's Avatar
Re: Hood Help
Use an aggressive sand paper to take the paint off then switch to about a 400 grit to smooth the metal prior to primer. The best way I found to remove the undercoating is with a putty knive and a small propane torch.
68_chop_top is offline   Reply With Quote
Old 06-11-2008, 09:40 AM   #3
lts70
1970 Daily Driver
lts70's Avatar
Re: Hood Help
Is 80 grit too aggressive? I just don’t want to go too low, at the same time I don’t want to waste time with too high of a sand paper grit.
Old 06-11-2008, 09:43 AM   #4
68_chop_top
Re: Hood Help
Just be careful and go slow. I have used 32 grit with an air DA sander. Get the paint off without scratching the metal. That's why you switch to 400 grit to smooth the metal. Metal scratches will show through the paint.
Mine is chopped, has a clutch, and a big block.
Old 06-11-2008, 09:43 AM   #5
lowriden58
lowriden58's Avatar
Re: Hood Help
80grit should be fine. but as stated switch to a finer grit to smoot it out. for removing the undercoating your best bet would be a small propane torch and a scraper
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 06-11-2008, 09:54 AM   #6
lts70
1970 Daily Driver
lts70's Avatar
Re: Hood Help
Thanks Guys. I have always wanted a small propane torch just never had a need. I guess my ditch burning unit might be a little too much for this project. I have a 5" dewalt orbital sander that I bought when I built the furniture for my house, that should work right?
Old 06-11-2008, 09:56 AM   #7
lowriden58
lowriden58's Avatar
Re: Hood Help
yeah that should work fine for the flat surfaces, but for the corners i would use a block
Old 06-11-2008, 10:07 AM   #8
lts70
1970 Daily Driver
lts70's Avatar
Re: Hood Help
Do I need to buy a block or can I make one out of a 2X4? If I can make one what dimensions should I cut the wood to? Thanks again guys.
Old 06-11-2008, 10:09 AM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: Hood Help
I have found that a heat gun and putty knife works much better than the torch for the undercoat...fewer fires and burns...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-11-2008, 10:52 AM   #10
Fastfun
Fastfun's Avatar
Re: Hood Help
If your previous hood had heat warp the last thing I would want to do is use a propane torch to remove the undercoating. I would use chemical stripper and a putty knive or the heat gun.
Fastfun is offline   Reply With Quote
Old 06-11-2008, 10:54 AM   #11
caminokid
Chevy nut
caminokid's Avatar
Re: Hood Help
I have been using 80 grit flapper disc to remove paint and rust. Been working really good.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-11-2008, 11:22 AM   #12
Sinisterspeed
Sinisterspeed's Avatar
Re: Hood Help
Paint thinner will take off the undercoating. Its not as fast but it wont damage anything either. Undercoat is petroleum based so any chemical thinner or stripper will take it off just makes a mess while your doing it. Myself I wouldn't but heat anywhere near a hood. As far as making a block harbor freight sells an air powered long board for under 30 bucks. (I hate harbor freight tools but for this tool I would use one) If your not a body man you wont use it much so I wouldn't spend the money on a better one. The one from harbor freight would work fine for a few uses at least. (might work forever)
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 06-11-2008, 01:45 PM   #13
Green Machine
Green Machine's Avatar
Re: Hood Help
Kerosene or diesel fuel works great to remove undercoat (if you can afford it !!!)
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
