Old 06-11-2008, 05:00 PM   #1
Deuce
Deuce's Avatar
Does a factory Tach dash require a ground wire??
I have a confirmed 12v at the back of the tach on the 12V side and have the "tach" wire hooked up to the HEI............but no tach movement.
Is there another lug that needs a ground wire???
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 06-11-2008, 06:45 PM   #2
byrd
Union Electrician
byrd's Avatar
Re: Does a factory Tach dash require a ground wire??
The cluster itself should have a ground lead from the back metal case to the truck. My truck doesn't have this ground and I have never had any trouble with tachs not working at all( believe me I have tested several hundred of these dashes). Most likely you have a bad tach or a bad connection in your tach wiring harness somewhere.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 06-19-2008, 01:47 PM   #3
raggedjim
raggedjim's Avatar
Byrd, do you have a test procedure for the tachs and other gauges?
I have a cluster I need to test...
Thanks, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
