06-11-2008, 05:40 PM | #1 |
Bagged front w/stock spindle.. how low???
I've searched w/no luck, i'm going to be bagging the front of my 67 this weekend with the bracket-cup kit from suicide doors and am curious how close my tire will be to hitting the inner fender w/the stock spindle.. I'll be running a 20" wheel and 255-35-20 tire, and figure its going to be close w/out a drop spindle, but dont have tires yet and truck is torn apart so mock up isnt really an option. I just dont want to spend the $300 on spindles if it'll give me an extra 1/2" in the end Anyone have pics of these trucks w/just bags up front, no drop spindle..?????
Also what are you guys doing with the bumpstop up front, im guessing hack it off?? Using slam re7's w/bumpstop's internally... thanks guys!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
06-11-2008, 07:20 PM | #2 |
One day...
Re: Bagged front w/stock spindle.. how low???
There was someone on here the other day that had one, and i think he mentioned that he didn't have spindles, it looked good, it just has more camber..
Where in OK are you? |
06-11-2008, 07:49 PM | #3 |
edmond-deer creek.. where abouts in okc you located
06-11-2008, 08:07 PM | #4 |
hey i found this for you he stock spindle hope this helps
http://67-72chevytrucks.com/vboard/s...d.php?t=294743 |
06-11-2008, 09:53 PM | #5 |
Not exactly "how low w/o drop spindles". That truck doesn't have drop spindles but does have a 3" frame 'Z'.
06-11-2008, 10:04 PM | #6 |
You can say that again, Scoti.
06-11-2008, 10:49 PM | #7 |
One day...
South 89th and May ave, north Moore area..
Thats the truck that schic4ever posted that i was talking about, but i didn't know it was Z'd. i would just guess from that pic 3 in taller would be approx what you would be at. that would give you an idea at least Last edited by scotts62; 06-11-2008 at 10:52 PM. |
06-11-2008, 11:28 PM | #8 |
senior member
i cant seem to find my old pics of this setup but i was running a 275/60/15 and the fender was about an inch away from the outer most part of the fender well, it looked stupid with the rear lower than the front so i bit the bullet and got drop spindles looks way better IMO
69 GMC bagged |
06-11-2008, 11:32 PM | #9 |
senior member
if this works i found a picture so this is a stock spindle with the same re7 bag ur running and on the rear no notch or anything just frame on axle action
69 GMC bagged |
06-12-2008, 12:43 AM | #10 |
pissonNOS.. you think your tires are larger overall than mine will be?? So your saying the truck could have went another inch lower w/a drop spindle
Can anyone just tell me how close i'll get to the inner fender w/the 255-35-20 and stock spindle?
06-12-2008, 12:46 AM | #11 |
senior member
i think i dropped more than an inch lower with the spindles the tire now hits the inner fender which i have to trim, i believe that the 275 is a 27inch tall tire someone else can confirm this im sure.
69 GMC bagged |
06-12-2008, 12:53 AM | #12 |
looks like your tires are 27.99" where mine will be 27.09" so about an inch of difference.. so anyone know now if a 27" tire on stock spindle will touch inner fender when fully aired out?????
06-12-2008, 12:18 PM | #13 |
On the fast track to nowhere..
Even adding 3" to mine probably won't be correct, I also have about a 3" cup welded into my lower arms for the bag to sit in and a 1.25" sectioned crossmember. I cut the bump stop bracket off of my lower arms and the flat part of the arm almost touches the upper crossmember. Here's a pic to give you an idea of what I'm talking about
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 06-12-2008 at 12:19 PM. |
